Thread: HVAC problems
Results 1 to 3 of 3
  1. #1 HVAC problems
    Iowa
    Recently encountered a problem with my HVAC system. Fan motor is only a few months old currently.
    When a/c is button is "on" The fan blows nice and consistent throughout the 5 speeds like it should. But when I turn the AC off and move the heat to high. The air the fan moves drastically decreases. On speed 1-3 I get almost nothing out of any of the vents. 4 and 5 is still moving way less air than it should be. Also on speed 5 with heat on...the heat only comes out of the middle 3 vents, and barely anything comes out of the 2 far left/right vents. Although when selected to blow on the floor, or defrost, every thing works perfect and blows hard. Although with the AC on everything works exactly as it should. Keep in mind heat itself is not the problem as the air is nice and warm like it should be.
    So in short, with heat on fan output is greatly decreased. AC blows exactly as it should.
    I am thinking something along the lines of the blend doors, or blend door actuators? Just looking for more opinions
  2. #2 Re: HVAC problems
    Omaha, NE
    I'm not an HVAC pro, but it sounds like the blend door actuator to me.
  3. #3 Re: HVAC problems
    SE Level Member KitRae's Avatar
    Jul 2012
    St. Catharines
    I am having the same issues in my 02 GP GT. Was told it could be the actual control module. Would check that first to be honest.
    Sent from my GT-S5690M
    2002 Grand Prix GT 3.8L Naturally Aspirated
    - NGK Iridium Performance Spark Plugs
    - NGK 51031 Performance Spark Plug Wires
    - EPR Cross Drilled Performance Brakes & Ceramic Pads
  1. hvac problems
    By nal13 in forum General Tech Discussion
    Last Post: 10-24-2013, 07:35 AM
  2. HVAC problems
    By Kahoutek1973 in forum General Tech Discussion
    Last Post: 05-12-2013, 07:50 PM
  3. Hvac and dic interference/problems
    By BLK01GTP in forum General Tech Discussion
    Last Post: 06-17-2012, 05:08 PM
  4. Hvac problems need help
    By asite57 in forum General Tech Discussion
    Last Post: 06-06-2012, 09:36 AM
  5. HVAC problems
    By seeth001 in forum 3.1L V6 (LHO/LG8)
    Last Post: 12-28-2009, 01:53 AM
