Thread: Hvac problems need help
Results 1 to 4 of 4
  1. #1 Hvac problems need help
    GTX Level Member asite57's Avatar
    Oct 2011
    Michigan
    alright so i get in my car let it run and then turn on the defrost, all of a sudden the oil light comes on so i turn the car off then the oil and seat belt light come on flash and the car chimes then the HVAC turns on i cant turn it off and ive completely removed the key from the car, like what the hell happened? is the HVAC fried? i cant turn it off its gonna kill my battery any help would be greatly appreciated right now i disconnected the battery and its sitting in my driveway
    info: its a bone stock 99 gtp 2dr with the digital HVAC
    SOLD. 99 GTP - Open Cone, ZZP STB ,GMPP Front & Rear Sway Bar, 3" DP & Cat-Back, Built Trans, 12'' Brakes, Tune
    http://www.grandprixforums.net/gtp-t...ack-67489.html
    04 SRT4 - Bone Stock....For Now
  2. #2 Re: Hvac problems need help
    Pennsylvania
    Did you put the battery back on? Just curious if it started up again when the battery was reconnected, or if unhooking it reset the system.
    Do you mean you turned everything off in the car and the blower fan kept running with the AC/Defrost on? And the knob to turn it off did nothing?
    Sport Edition Kv5 18x8
  3. #3 Re: Hvac problems need help
    Oct 2011
    Michigan
    i have not tried anything yet because its 1am and freezing where i am, i was just hoping someone else had this problem before and could give me some advice
  4. #4 Re: Hvac problems need help
    Oct 2011
    Michigan
    anyone have any ideas?
  1. DIC HVAC gone..
    By Jay7199 in forum General Tech Discussion
    Last Post: 06-07-2011, 10:03 PM
  2. Will Dual HVAC Work in Stock HVAC
    By ljmonnin12 in forum General Tech Discussion
    Last Post: 11-25-2010, 10:57 PM
  3. HVAC help
    By 3800SE in forum General Tech Discussion
    Last Post: 03-07-2010, 07:02 PM
  4. HVAC problems
    By seeth001 in forum 3.1L V6 (LHO/LG8)
    Last Post: 12-28-2009, 01:53 AM
  5. 04 hvac
    By Scott Francis in forum Introductions/Noob Questions
    Last Post: 10-16-2009, 03:36 PM
