Thread: !Rear turn signal But no Tail Light!
Results 1 to 7 of 7
  1. #1 Re: !Rear turn signal But no Tail Light!
    sounds like a bad socket. id poke it with a test light see if it lights up.
    a lot of these bulb sockets un clip off the wires. if it does take it off, test for power at the plug. ive had sockets go bad. its a easy change even if you need to cut it off and solder on a new socket.
    with the moisture problem in the GP's tail lights have id be thinking socket.
  2. #2 Re: !Rear turn signal But no Tail Light!
    KSteelwheelzJ klj5022's Avatar
    New Carrollton,MD
    I went and took a water vinager mixture with a Q-Tip and cleaned out the socket and now it works. Thanks for all the help.
    I just wish the police loved my car as much as i do 3.5,160 Stat,HAI,ZZP F/R STB, SSAC Headers, Reptile PCM
  1. Brake light and turn signal issue
    By BlackGT97 in forum General Tech Discussion
    Last Post: 07-13-2014, 01:21 PM
  2. no right brakel light/turn signal
    By jjlw in forum General Tech Discussion
    Last Post: 04-01-2013, 11:09 PM
  3. 08 turn-signal & brake light issue
    By Dee Johnson in forum General Grand Prix Discussion
    Last Post: 10-03-2012, 02:22 PM
  4. Right Rear Turn Signal Out But Light Is Still On?
    By Joseph27705 in forum General Tech Discussion
    Last Post: 06-28-2012, 06:01 PM
