Thread: Washer solvent pump replacement.
Results 1 to 15 of 15
  1. #1 Washer solvent pump replacement.
    GTX Level Member 98buicksupercharged's Avatar
    Oct 2012
    Fort Wayne, Indiana
    So I'm replacing my washer solvent pump tomorow cause mine went out. Is the only way of getting to it by taking off the front bumper. And is there a trick. This is in my 2001 gtp
    2001 sliver gtp her name is Reagan
  2. #2 Re: Washer solvent pump replacement.
    if you pull the inside wheel liner you can reach in and pull it off the tank. its a easy fix.
  3. #3 Re: Washer solvent pump replacement.
    Oct 2012
    Fort Wayne, Indiana
    The pump is facing the outside though so won't it be hard to reach in
  4. #4 Re: Washer solvent pump replacement.
    i can see mine from under the car in the regal, so if you get it up on ramps you may be able to reach right up to it from under the car too.
    pretty sure i could get to it if i took the head light out too.
  5. #5 Re: Washer solvent pump replacement.
    Oct 2012
    Fort Wayne, Indiana
    Gotcha. I'll pull it in to work actually now so I can just stand under and see if I can reach up
  6. #6 Re: Washer solvent pump replacement.
    Oct 2012
    Fort Wayne, Indiana
    No luck. I have to drop the skip plate thing
  7. #7 Re: Washer solvent pump replacement.
    just pull like 3 or 4 of the plastic wheel well lining clips and pull it back and reach in.
  8. #8 Re: Washer solvent pump replacement.
    Oct 2012
    Fort Wayne, Indiana
    I will tomorrow. Id rather sit on my ass at work lol
  9. #9 Re: Washer solvent pump replacement.
    GTP Level Member indygrandprix's Avatar
    Jan 2012
    Indianapolis
    You can do it with the tire on car on the ground and everything together except the wheel well liner, i did it on mine a few months ago.
    Theres like 2 or 3 6mm or so bolts holding the wheel well liner to the bottom of the bumper cover and then take off a few of the phillips screws holding it to the fender and pull it back. You should see the washer pump. unplug the wires running to it and then with the new pump in hand pull the old pump out and take the hose off and quickly put the new one in. (If there's fluid in there it will come pouring out. If its dry then don't worry about doing it quickly)
    I went NA when a whore left -$300 in my bank account.
  10. #10 Re: Washer solvent pump replacement.
    Moderator Russosaur's Avatar
    Apr 2012
    Dayton, OH
    Just don't pull a me and fill the thing up thinking it was empty then have a big mess in the garage lol
    Sent from my HTC Thunderbolt using Tapatalk
    2012 F150 STX
    - Gonna be a race truck
  11. #11 Re: Washer solvent pump replacement.
    Dec 2013
    You can remove the headlight and get your arm down through the opening and get it in and out. You wont be able to see it so it will all be by feel.
    Sent from my SCH-R970 using Tapatalk
  12. #12 Re: Washer solvent pump replacement.
    St. Louis
    Haha! Sorry, that's just funny as I've seen it done before. The look on people's face when they remove the pump and all of the sudden Niagra falls, lol.. Yea, if the res. is full, it won't been when you're done.
  13. #13 Re: Washer solvent pump replacement.
    Apr 2012
    Dayton, OH
    Just don't fill it up with water for the winter time. Ask me why not...
    2012 F150 STX
  14. #14 Re: Washer solvent pump replacement.
    Oct 2012
    Fort Wayne, Indiana
    That's just dumb lol
  15. #15 Re: Washer solvent pump replacement.
    Hmm my car has a little flap thingy right there I the wheel well liner.
    Sent from my SAMSUNG-SGH-I747 using Tapatalk
  1. Washer pump not working
    By camopaint0707 in forum General Tech Discussion
    Last Post: 06-21-2013, 06:21 AM
  2. Windshield washer pump?
    By MNGPGT in forum General Grand Prix Discussion
    Last Post: 12-13-2012, 10:13 PM
  3. Washer Fluid Not Pumping After Pump Replacement (PHOTO UPLOADED)
    By Adidasdude1989 in forum General Tech Discussion
    Last Post: 07-07-2012, 03:10 PM
  4. washer fluid pump
    By thewaitinggame in forum General Tech Discussion
    Last Post: 04-26-2011, 08:17 PM
  5. washer pump????
    By GTPJOE90 in forum General Tech Discussion
    Last Post: 06-12-2010, 11:24 PM
