Thread: Did my Power steering just went out?
Results 1 to 9 of 9
  1. #1 Did my Power steering just went out?
    Nov 2011
    Michigan
    2006 Pontiac Grand Prix Base.
    Today my car was stuck on an unplowed snowed in road. I had trouble getting the car out, I kept turning the wheel to get out and finally i got out of the mess. I realized as I was driving how hard it was to turn the wheel. I thought it was the snow jammed into the wheel but once I got on the highway, I still had a hard time steering. I am starting to believe my power steering went out. Any thoughts??
    thanks
  2. #2 Re: Did my Power steering just went out?
    Feb 2013
    37.295091, -121.930053
    You may have air in the lines. add some ps fluid and turn the wheel back and forth tell it softens. Also there may be a hole in the line. Did it mark its territory with a puddle?
    im a cookie again yay me
    please learn to forum better.
    ^^new favorite quote
  3. #3 Re: Did my Power steering just went out?
    GTP Level Member indygrandprix's Avatar
    Jan 2012
    Indianapolis
    Start by checking your fluid level.
    Can you hear the pump whining... any fluid on the ground
    I went NA when a whore left -$300 in my bank account.
  4. #4 Re: Did my Power steering just went out?
    Nov 2011
    Michigan
    I am going to check right now. So far no puddle on the ground. No steering noices at all. It is very hard to turn the wheel.
  5. #5 Re: Did my Power steering just went out?
    Denver
    Is your serpentine belt broken/loose?
    Did you check the level of the power streering pump?
  6. #6 Re: Did my Power steering just went out?
    Nov 2011
    Michigan
    How in the heck do you check your power steering?? is it under something?
  7. #7 Re: Did my Power steering just went out?
    Jan 2012
    Indianapolis
    It's on the back passangere side of the motor underneath the heater core hoses. Bring a flash light to check the level. It's dark back there
  8. #8 Re: Did my Power steering just went out?
    Feb 2013
    On the 97-03 its on the passager side under the alt but on an 06 im not sure. To check if its leaking make sure its filled up then run it and look under it to see if its leaking
  9. #9 Re: Did my Power steering just went out?
    Nov 2011
    Michigan
    Power steering pump was cracked. It was replaced and is now running good.
  1. Power steering help!
    By aboul012 in forum Introductions/Noob Questions
    Last Post: 11-23-2012, 09:39 AM
  2. power steering
    By pacothetaco in forum General Tech Discussion
    Last Post: 07-28-2011, 10:15 AM
  3. power steering. feels like i have "half" the power
    By colindunn in forum General Tech Discussion
    Last Post: 07-23-2011, 09:15 AM
  4. power steering?
    By X97prixX in forum General Tech Discussion
    Last Post: 01-14-2010, 04:02 PM
  5. Power Steering
    By Pontiac Warrior in forum Brakes/Suspension/Chassis
    Last Post: 07-07-2009, 11:51 PM
