Thread: Car turns over, but won't start without giving it some gas
Results 1 to 20 of 28
  1. #1 Car turns over, but won't start without giving it some gas
    GT Level Member K Kraziee's Avatar
    Apr 2013
    Milwaukee
    I recently installed a ZZP ported throttle body and since I did this, my car turns over, but won't start without hitting the accelerator to get it up and running. When it's warm it starts rough, but gets going on it's own. I'm thinking the butterfly might be stuck closed not allowing air to get through when cold. I reset the battery and double checked the throttle cable and tightness of the throttle body and all is well. Any suggestions?
    DD: 2000 Pontiac Grand Prix GTP
    3.5 ZZP MPS, HAI, ZZP Ported Throttle Body, PLOG, 3" Catless DP, Water pump and Alt. UD Pulley, Custom Tune
  2. #2 Re: Car turns over, but won't start without giving it some gas
    Pennsylvania, USA
    Idle air control valve working properly? And the correct tension on the throttle cable? There's not much else it could be. Maybe start it with the tubing off or a second to see if you can spot anything strange. Watch it while someone starts the car.
  3. #3 Re: Car turns over, but won't start without giving it some gas
    Apr 2013
    Milwaukee
    Ya, I was thinking it could be a sensor. I got new sensor's with the throttle body so maybe one was bad. It's weird though because once it starts it idles normal. I'll check the throttle tension again, though it should be fine.
  4. #4 Re: Car turns over, but won't start without giving it some gas
    Are you tuned for the tb?
  5. #5 Re: Car turns over, but won't start without giving it some gas
    Apr 2013
    Milwaukee
    No, I was told by zzp I wouldn't need a tune. It's there stage 1 throttle body.
  6. #6 Re: Car turns over, but won't start without giving it some gas
    Apr 2013
    Milwaukee
    Also my supercharger made a weird noise when I let off the gas after boosting. Like air was getting trapped somewhere, it was a louder whine then normal. It drives fine and seem's to idle ok so this really boggles my mind lol
  7. #7 Re: Car turns over, but won't start without giving it some gas
    Larger throttle bodys need a tune, always.
  8. #8 Re: Car turns over, but won't start without giving it some gas
    id put the stock TB back on and see how it runs. if its better you know the TB is a problem of some sort.
  9. #9 Re: Car turns over, but won't start without giving it some gas
    Apr 2013
    Milwaukee
    The problem is I already sent it to zzp for my core return. So I'm stuck with this one for now. I'm going to try to switch out the tps and see if that's the problem. It sometimes surges when accelerating from a certain speed. It's worth a shot.
    Sent from my PantechP8010 using Tapatalk
  10. #10 Re: Car turns over, but won't start without giving it some gas
    if that dont help maybe take it off and make sure it moves smoothly and dont bind up or something.
    maybe pick up a TB from a JY.
  11. #11 Re: Car turns over, but won't start without giving it some gas
    Apr 2013
    Milwaukee
    Ya, I'll do that. I'm hoping it's the tps cuz it idles fine once I give it gas so I'm thinking it can't really be the iac. I'll let you guys know if the tps is the culprit.
  12. #12 Re: Car turns over, but won't start without giving it some gas
    Apr 2013
    Milwaukee
    Calling ZZP liars?! lol jk
  13. #13 Re: Car turns over, but won't start without giving it some gas
    Yup I would grab a stocker from the JY and try that and then like the others have said you'll know if the new TB is the issue.
    04 Comp G.
  14. #14 Re: Car turns over, but won't start without giving it some gas
    Dec 2013
    Millerstown Pa.
    MAF sensor?
  15. #15 Re: Car turns over, but won't start without giving it some gas
    Apr 2013
    Milwaukee
    MAF should be good, replaced about 6 months ago. I got the tps put on last night and it drove fine. A little rough start again, but I'll have to see what happens when I try to start it cold.
  16. #16 Re: Car turns over, but won't start without giving it some gas
    Apr 2013
    Milwaukee
    Well I installed the TPS and my car run's better, but still doesn't want to start when cold. I will have to pick up a tb from the yard at some point. Thanks for your guys' input.
  17. #17 Re: Car turns over, but won't start without giving it some gas
    I have a tb from a 99 without a maf I'll sell cheap.
  18. #18 Re: Car turns over, but won't start without giving it some gas
    Apr 2013
    Milwaukee
    Ok, I'll check the jy and get back to you. Also the vacuum hose that connects to the throttle body was cracked so I duct taped it. Do you know where that hose leads too?
  19. #19 Re: Car turns over, but won't start without giving it some gas
    Evap stuff most likely
  20. #20 Re: Car turns over, but won't start without giving it some gas
    Apr 2013
    Milwaukee
    Ok, that was disabled with my tune so I should be good there.
  1. 04 GP turns over no start
    By jjlw in forum General Grand Prix Discussion
    Last Post: 04-26-2013, 11:11 AM
  2. Turns Over But wont Start
    By ambersmom1819 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 12-20-2012, 04:44 PM
  3. Engine turns over but will not start
    By rockytop104 in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 10-04-2010, 10:17 AM
  4. 00 GT wont start but turns over
    By dwagn313 in forum Introductions/Noob Questions
    Last Post: 06-18-2010, 06:30 PM
  5. Car wont fully start without giving it gas... wtf
    By Piggy in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 06-15-2009, 05:41 PM
