Thread: Need help with a new gauge install
Results 1 to 3 of 3
  1. #1 Need help with a new gauge install
    Jan 2012
    Philadelphia
    I got my hands on a older knock gauge it came out of an 89 TTA it was popular on them and the Grand Nationals. Anyway I got the gauge for free and it works. Im not sure If its possible to put in a GTP and make it functional or not. Ive done some research and have not seen many people install this gauge and I know its set up for older cars that are not OBD2. I found the directions for it and not sure how I would go about hooking it up. I know about the + and - but im wondering if there might be a way to tie it into the PCM or hook it up to a knock sensor. If there is a way to get this gauge to work? It could be a new way to measure KR cheaper then an Aeroforce, I already have an Aeroforce so I would be able to see how it would compare to actual KR numbers. Just a thought because I have this gauge already and would like to use it if possible.
    These are the instructions here
    http://www.installationinstructions.com/102003.pdf
    The model number is 102003 made by Caspers Electronics, Here is the gauge
  2. #2 Re: Need help with a new gauge install
    Jan 2012
    Philadelphia
    No one has any idea? Open to opinions
  3. #3 Re: Need help with a new gauge install
    May 2013
    RI
    The instructions say that pin C is the input the gauge gets from the knock sensor. Try hooking up pin C to one or both of the knock sensor inputs to the pcm.
  1. pillar gauge install
    By ILoveAudi in forum General Grand Prix Discussion
    Last Post: 07-21-2013, 10:00 AM
  2. help me install my boost gauge!
    By des19 in forum General Tech Discussion
    Last Post: 08-22-2012, 06:01 AM
  3. Gauge install help...a-pod
    By blortz in forum Audio, Security & Visual Electronics
    Last Post: 07-31-2011, 11:26 AM
  4. AeroForce Gauge install
    By itsjay in forum Audio, Security & Visual Electronics
    Last Post: 02-22-2010, 10:15 PM
  5. AFR gauge install
    By amwhitey in forum General Tech Discussion
    Last Post: 02-03-2010, 01:25 PM
