Thread: pillar gauge install
Page 1 of 3 123 LastLast
Results 1 to 20 of 43
  1. #1 pillar gauge install
    Never Be A Tim. ILoveAudi's Avatar
    Aug 2012
    Middle of Nowhere, OH
    Just curious. How hard is it to install pillar gauges?
    1998 GTP Coupe - DIY Intake, Stock - 178k miles with rusty weight reduction (sold)
    1998 GTP Sedan - CT turbo kit, billet wheel pt61, s1x blower cam, Iceman stage 3 heads, 90# springs for all the valve floatz, walbro pump, fuel pump rewire *slowest s1x build ever*
  2. #2 Re: pillar gauge install
    Banned
    Jan 2013
    Colorado
    Not hard at all. The sending units on each gauge could be more difficult but otherwise it's pretty simple.
  3. #3 Re: pillar gauge install
    As easy as a oil change.
    04 Comp G.
  4. #4 Re: pillar gauge install
    Aug 2012
    Was thinking about getting a 2 gauge pillar. Other than boost/vacuum, not sure what I'd want to run on the other gauge or what would be the easiest to hook up.
  5. #5 Re: pillar gauge install
    Aeroforce
    04 Comp G.
  6. #6 Re: pillar gauge install
    GTP Level Member 231FUN's Avatar
    Dec 2011
    Ontario,Canada
    Aeroforce
  7. #7 Re: pillar gauge install
    Aug 2012
    Someone please explain this to me. I've heard the term, but never understood exactly what is. Noob here :/
  8. #8 Re: pillar gauge install
    Banned
    Jan 2013
    Colorado
    google it, look it up on their website too
  9. #9 Re: pillar gauge install
    Aug 2012
    Well what kind of aeroforce gauge?
  10. #10 Re: pillar gauge install
    Aug 2012
    If one gauge has so many functions why would I need 2?!
  11. #11 Re: pillar gauge install
    Banned
    Jan 2013
    Colorado
    you can only read two at once
  12. #12 Re: pillar gauge install
    Quote Originally Posted by camopaint0707 View Post
    Actually you can read 8 at one time, for 4 seconds each. Its called Cycle Scan.
    Otherwise at a click of the button its switched back to reading 2 at a time where you can toggle through your selected "gauges".
  13. #13 Re: pillar gauge install
    Aeroforce scan gauge
    04 Comp G.
  14. #14 Re: pillar gauge install
    Aug 2012
    Thanks! I might have to do that! But I'll probably just go with normal gauges because of the money factor
  15. #15 Re: pillar gauge install
    GT Level Member JaredR215's Avatar
    Jul 2011
    Cheyenne
    If you plan on modding at all, buy an aeroforce. It's worth it. They come up in the for sale section quite often for decent prices.
    K&N Cold Air, ZZP Wires, ZZP 3" with hi-flo, Catback, ZZP 1.0 PCM., 180*, AL605's, 3.5 MPSStill fighting KR
  16. #16 Re: pillar gauge install
    Apr 2012
    Bancroft. Ontario, Canada
    Quote Originally Posted by JaredR215 View Post
    This!
    Even if you are not modding, an Aeroforce scan gauge is a VERY VERY wise investment..
  17. #17 Re: pillar gauge install
    Aug 2012
    I don't plan on going ham with performance mods. I don't see a need for such an expensive gauge either.
  18. #18 Re: pillar gauge install
    It can still benefit from one even in stock form
    04 Comp G.
  19. #19 Re: pillar gauge install
    Aug 2012
    I'm in high school, the fact that I'm even spending money is crazy. No need to spend more than I want to.
  20. #20 Re: pillar gauge install
    Fair enough
    04 Comp G.
  1. A-Pillar Gauge Pod and Gauges - ease of install?
    By winterstorm in forum General Tech Discussion
    Last Post: 07-22-2012, 04:16 PM
  2. ZZP New Gauge Pillar 04+
    By gtx3800 in forum 04+ Specifics
    Last Post: 04-23-2012, 10:41 AM
  3. Gauge pillar install
    By jdmgtp in forum General Tech Discussion
    Last Post: 06-17-2010, 06:17 AM
  4. Gauge Pillar
    By Everblades2 in forum Visual/Body Modifications
    Last Post: 01-09-2010, 10:38 PM
