Thread: Computer monitoring?
Results 1 to 20 of 31
  1. #1 Computer monitoring?
    GTP Level Member chris99gtp's Avatar
    Jun 2012
    Illinois
    hey guys is there any free software to scan my car on my computer if i get a Bluetooth obdII adapter? or maybe an cheap software? i'm just looking for a cheap way to monitor my car.
    Thanks
    Chrisk
    99 gtp- Burnt and gone
    01 gtp- Here to stay-3.4, SD Headers, AL104's HAI, Overkill PCM, SD Hood
  2. #2 Re: Computer monitoring?
    GT Level Member cmal37's Avatar
    May 2011
    Tampa FL near USF
    http://torque-bhp.com/wiki/Main_Page
    This is what some of us use
    GMPP Struts, F body brakes, CAI, Ubend, resonator, and cat delete, 180tstat, SD headers, 3.4 Pulley, OverKill PCM,http://www.grandprixforums.net/my-bl...res-60017.html
  3. #3 Re: Computer monitoring?
    Phone apps aren't very spot on for many things.
  4. #4 Re: Computer monitoring?
    May 2012
    Where winter never ends
    There are applications that allow you to scan via your PC Bluetooth; however, they usally cost money. Scan XL For example (which I think allows Bluetooth runs around 89 iirc) If you just want general information use the app listed above.
    Or if you feel like it and know how to program write you own application! :P Its just serial bluetooth ports and reading some data coming in!
    2000 Regal - Winter Beater
  5. #5 Re: Computer monitoring?
    Jun 2012
    Illinois
    since im not really modded, i would just use it to monitor things(mostly Kr) and see where its at. but when i start getting serious into modding i will buy an aeroforce.
    chris
  6. #6 Re: Computer monitoring?
    May 2012
    Use the app.
  7. #7 Re: Computer monitoring?
    Sep 2011
    Copperas Cove, TEXAS
    I paid $15 for my 327 ELM BT adapter, $5 for the Torque app, The Torque app has worked for me very well, yet it would be nicer to have mechanical gauges.
    Here is what I monitor with my Torque App
  8. #8 Re: Computer monitoring?
    Nov 2011
    NY
    its funny you picture the two items together... I'm going to try and see if I can fashion a way to mount my old phone in place of the DIC to be able to show torque pro gauges, etc. lol... But that'll be in the Spring (project). : )
  9. #9 Re: Computer monitoring?
    I live here. DirtDog's Avatar
    Jun 2012
    I have a computer monitoring program. Only cost 650
  10. #10 Re: Computer monitoring?
    Nov 2011
    NY
    The Bluetooth/Torque app is the cheapest way to "ACURATELY" monitor what your engine is doing in absence of separate physical gauges. The better BT adapters can monitor at a faster RATE, which may allow for the monitoring of MORE items. The AEROFORCE and cheap BT adapters BOTH read the PCM through the OBDII connection so are REPORTING the SAME information!
    I don't get how people bash the BT adapter/app (Torque Pro) route when it is the same exact thing?
    I don't vouch for any other app...
    I have done a run with my HPT monitoring and recording and then removed it and did the same run with BT/Torque and it was the same. The trick is to not load the app with too many items to monitor, but three pages loaded with all the pertinent gauges and recording was fine. If you load too many all it will do is SLOW down the data flow, not CHANGE IT.
    I have been using torque pro since it was first out and it is probably one of the best written apps hands down!
  11. #11 Re: Computer monitoring?
    Jun 2012
    Illinois
    sweet thanks for the help everyone!
  12. #12 Re: Computer monitoring?
    Sep 2011
    In the picture I posted, those gauges are the only thing I have running on the App, it's very accurate.
  13. #13 Re: Computer monitoring?
    Nov 2013
    Wisconsin!
    I just downloaded this....and I cant seem to find where to add the KR gauge to the realtime screen. Can anyone give me some pointers? Thanx
  14. #14 Re: Computer monitoring?
    Sep 2011
    Send dsmuts a PM, he helped me with mine.
  15. #15 Re: Computer monitoring?
    Nov 2013
    Wisconsin!
    Thanks! I got it figured out!
  16. #16 Re: Computer monitoring?
    Jun 2012
    Illinois
    Is it iphone compatible?
  17. #17 Re: Computer monitoring?
    Jun 2012
    Illinois
    BUMP! does anyone know an iphone app to help me scan? I'm using the engine link app but it doesn't give me numbers for knock and such. Just basic information.Any help would be appreciated
    chris
  18. #18 Re: Computer monitoring?
    Nope torque seems to be the only one and that a android app.
    04 Comp G.
  19. #19 Re: Computer monitoring?
    SE Level Member Buggsy's Avatar
    Eau Claire, WI
    The iPhone suffers from a terrible Bluetooth design. As such, most of the apps that I've seen are paired with a device that was built to work with the iPhone. This is the only one that I've heard of:
    http://www.actron.com/product_detail.php?pid=16367
    It's more common for an Apple user to go buy a cheap Android phone/tablet from from Craigslist or ebay and buy the $5 Torque app. The Apple options that work are pretty expensive.
  20. #20 Re: Computer monitoring?
    Jun 2012
    Illinois
    Will a wifi adapter work with the torque app? That's what I got for my iPhone and it doesn't really work
  1. question about tire monitoring system
    By DirtDog in forum Tires & Wheels
    Last Post: 01-06-2013, 09:37 PM
  2. How to reset tire pressure monitoring system?
    By gpcruzin in forum Tires & Wheels
    Last Post: 12-07-2011, 12:06 PM
  3. Chrome Wheels/Tire Monitoring System
    By cmw1876 in forum General Tech Discussion
    Last Post: 03-28-2009, 02:11 PM
  4. tire pressure monitoring system light
    By uti grand prix in forum General Tech Discussion
    Last Post: 10-02-2008, 09:13 PM
  5. Monitoring IC temps
    By IndeedSS in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 06-23-2008, 09:28 PM
