Thread: Radiator problems
Results 1 to 20 of 23
  1. #1 Radiator problems
    Donating Users onetyme77's Avatar
    texas
    What causes this and how do I fix it.
    98 GT N/A 4door
    Sent from my SCH-I535 using Tapatalk 2
  2. #2 Re: Radiator problems
    Dec 2010
    DMV
    Dexcool causes that. I suggest a coolant flush immediately and switching to the orange stuff.
    Sent from my HTC One using Tapatalk
  3. #3 Re: Radiator problems
    texas
    Had it flushed about a year ago. The place that did it says they use a coolant that works with both red and green. (I don't remember what color theirs was) I thought after I had it flushed it wouldn't happen again.
    So basically another flush...
  4. #4 Re: Radiator problems
    St. Louis
    Air in the system can also cause Dex to do that. I'd flush it, drive it for a while and flush again then refill w/ conventional green coolant. Might want to consider backflushing the heater core as well.
    You aren't loosing any coolant are you? Being a 98 I'd think you have had the LIM gaskets done by now.
  5. #5 Re: Radiator problems
    texas
    Quote Originally Posted by FordMan77 View Post
    My grandfather SAID he had the LIM's replaced for me about a year ago but I'm very skeptical. Engine looked the same when I got my car back. ( It's on MY to do list.) and I think I am losing coolant, just added a gallon today. It's not hitting the ground tho, it's burning off, but I don't smell it.
  6. #6 Re: Radiator problems
    GTX Level Member hensleya1's Avatar
    Jun 2013
    Beavercreek, OH
    You've got a Dexcool problem there, bud.
    Quote Originally Posted by hensleya1 View Post
    To nuke the entire site from orbit 'cause it's the only way to be sure:
    1) Replace the radiator, hoses, and coolant bottle. Don't be surprised if the heater core springs a leak in the future and needs replaced too.
    1a) Do a LIM gasket as even if you have an aluminum one. Dexcool eats aluminum.
    2) Backflush the block. Put a hose in one end, turn it on, go get a burger, come back half an hour later. You'll never get 100% of it out, but the block is made of iron, dexcool doesn't eat that.
    3) Refill with green coolant. Never look back.
    2003 GT Limited Edition 199k - The $600 winter beater.
    2004 Buick LeSabre 172k - Top Swapped, 3.5 pulley, 1.9 rockers, SLP headers... still slow...
    MAKE AMERICA FAST AGAIN!
  7. #7 Re: Radiator problems
    texas
    Thanks for the info
  8. #8 Re: Radiator problems
    texas
    When they say back flush. How is that done? I've flushed a radiator before, just not sure if "back" flushed it.
  9. #9 Re: Radiator problems
    Jun 2013
    Beavercreek, OH
    Quote Originally Posted by onetyme77 View Post
    Coolant flows from the radiator through the bottom hose, through the block to the top, and back to the radiator through the top hose. By backflushing, you're pulling the top hose out of the rad and dumping water in there. I recommend also loosening the bottom hose from the radiator (leave it attached to the block, though), and point it towards a bucket/drain pan of your choice. Flush away.
    If it's really caked in there, run straight water with two bottles of Prestone flush/cleaner for three days (which may be dicey as it gets colder, depending on where you live), and then flush again.
    If you're lucky, you'll not have to replace the rad/heater core, as Dexcool shortens their lives.
  10. #10 Re: Radiator problems
    texas
    Welp! She over heated today. Pulled in the yard, temp hand was WAY high, but light never came on. Steam and coolant bellowed from under the hood. Popped hood and the steam was coming from the passenger side of the motor near the water pump. Engine was too hot to check out and it's too darn cold out side also. Just based on that info can any one give me an idea at what's wrong or what may need to be fixed?
    My thoughts as of now (along with severe aggravation, because I don't have the money, time and it's too cold for me to work on it) new radiator, new heater core, flush, replace upper and lower gaskets.
  11. #11 Re: Radiator problems
    how to flush the coolant.
    remove the t stat, put the t stat housing back on, take the upper hose off the radiator, then push it down to the ground to a bucket or let it fly.
    get your garden hose out, put it in the rad turn it on, then fire up the car, let it run till clear water pumps out the top hose.
    then turn the hose off, run the car till no more water comes out the upper hose. then turn it off.
    put your t stat back in, with new gasket, the upper hose back on.
    now take 1 gallon of full strength green antifreeze, not the 50/50 crap. ( parts store cheap green is fine to use) dump the whole gallon in the radiator, fire up the car, fill the rad with hose water till its full. top as needed till its ready to be bled of air. it will burp and take coolant as the water in the block warms up the t stat opens up for a few seconds till cold coolant hits it and it shuts again.
    now to bleed the air out, let it idle rad cap off till the fans turn on, (when the fans are on the temp is over 195 deg, the t stat is wide open) then open the bleeder screw on top the t stat housing a few turns till a steady stream of coolant comes out the hole, shut the screw, top off the rad. cap it.
    done.
    once it cools off check your coolant elbows, one may be leaking.
    the lim gaskets, look on the side of the head where the lim meets the head, if you see a silver gasket your ok, black, you need to change it.
    being your n/a the upper gasket may have failed and is leaking into the lower intake. or the intake has a crack by the egr tube.
  12. #12 Re: Radiator problems
    GT Level Member K Kraziee's Avatar
    Apr 2013
    Milwaukee
    Hopefully your headgasket's ok.
    DD: 2000 Pontiac Grand Prix GTP
    3.5 ZZP MPS, HAI, ZZP Ported Throttle Body, PLOG, 3" Catless DP, Water pump and Alt. UD Pulley, Custom Tune
  13. #13 Re: Radiator problems
    texas
    I checked the oil right after I shut it off and it was all oil. So yes, I too hope I didn't crack a head nor blow a head gasket
  14. #14 Re: Radiator problems
    St. Louis
    You didn't blow a head gasket. They rarely go on these cars even if overheated. What likely happened is that the upper coolant elbow ruptured and sent coolant everywhere, which just happens to be located above the waterpump.
    If you take a look at the LIM where it meets the head on the passenger side and see black between the 2 then the LIM gaskets need to be done. If you see aluminum/grey color then they have the updated gaskets.
  15. #15 Re: Radiator problems
    texas
    Finally had a chance to look things over... As figured I don't see anything other than coolant sitting in spots on the frame. I don't even know what to check. I let it run for about 5 min. Temp gauge never moved. No hissing or spewing.
    I'm thinking of just replacing the radiator, thermostat, coolant bottle, both hoses and that plastic elbow that's goes to the tensioner. Opinions/advice please
    Can someone post a link for the how to replace the ac/heater fan (blower)
  16. #16 Re: Radiator problems
    compression test the cylinders or pressure test the cooling system, either tool can be had via the free tool rental deal.
  17. #17 Re: Radiator problems
    texas
    So u think the cooling system can be saved? I was figuring with all of that Dexcool sludge and the age of the car, to just replace the rad.
  18. #18 Re: Radiator problems
    that depends on if the rad is clogged up.
    if you pull both hoses off the rad, put a hose in the lower port and a hand over it to seal it off some what, and let it flow up and out the top port, that will back flush it.
    then fill it and let the the lower hose just dump, aka let it drain as fast as it will. it should drain rather fast if not clogged.
    then theres the cooling system flush/cleaners. that should clean up the rest of inside the engine.
    that brown snot can keep showing up for years tho, yours does seem to be thick on the cap. i get little boogers on mine here and there.
  19. #19 Re: Radiator problems
    texas
    Even if I change the rad, hoses and bottle it will still show up later?
  20. #20 Re: Radiator problems
    Dec 2012
    Where 4T65E's were born
    It will but in small amounts. Depends on how good of a flush you do. Given that it's that bad, it should really be driven for a week or two with water and flushing cleaner, as long as there's no chance of freezing. You say cold, but my definition of cold is the weather outside my house right now, 20°F. (just looked at weather for texas, low is 31 for tonight but after they're plenty safe) After a week or two of water and flushing fluid, I bet a ton of that sludge will have broken up and surfaced in the rad, which you must flush the system again and maybe use the same stuff until it stays clean.
    Sold.
  1. Cooler line pops out at radiator. Dealership says I need a new radiator?!?! Pic
    By nickbuol in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 02-27-2013, 08:27 PM
  2. Radiator Fan Problems
    By CarFixer in forum General Tech Discussion
    Last Post: 02-20-2012, 01:36 PM
  3. Two Problems: Rusted Radiator and No AC
    By SlyBlackDragon in forum General Tech Discussion
    Last Post: 02-12-2012, 09:40 AM
  4. Weird radiator problems...
    By CSteen85 in forum General Tech Discussion
    Last Post: 03-24-2010, 02:37 PM
  5. radiator problems
    By 99prixgt in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 02-01-2009, 05:21 PM
