Thread: Door unlocks but doesn't lock
Results 1 to 12 of 12
  1. #1 Door unlocks but doesn't lock
    Oct 2013
    WI
    I'm thinking it's the actuator but would like a second opinion.
    Both doors unlock through all methods, fob, switch, etc, but the driver's will only lock using the manual lever. It won't lock through the switch, remote, or coming out of park. I tested the switch on a meter and it appears ok, and swapped it with the other side. I do see a pulse of power at the actuator when trying to unlock. All signs seem to point there, though it does seem a little unusual it fails only one way, I assume there's a motor or similar in their that goes one way to lock and the other to unlock. Maybe some teeth went.
  2. #2 Re: Door unlocks but doesn't lock
    Hmm, not 100% sure. Go with your gut?? LOL.
  3. #3 Re: Door unlocks but doesn't lock
    Omaha, NE
    Sounds like the door lock motor.
  4. #4 Re: Door unlocks but doesn't lock
    Feb 2013
    37.295091, -121.930053
    I say a broken wire. Had that in a Durango driver couldn't unlock found out a wire snaped on the switch so glue now holds it in place
    im a cookie again yay me
    please learn to forum better.
    ^^new favorite quote
  5. #5 Re: Door unlocks but doesn't lock
    Omaha, NE
    I disagree, only because he said he is getting good voltage to the sensor harness.
  6. #6 Re: Door unlocks but doesn't lock
    Feb 2013
    So did mine lol. Its one of 2 thing broken wire or bad switch. Its something simple
  7. #7 Re: Door unlocks but doesn't lock
    Omaha, NE
    Simple = Complicated.
  8. #8 Re: Door unlocks but doesn't lock
    Oct 2013
    WI
    Well, got my new actuator and have the same issue. I've currently got the door lock/actuator/rods out and doing some bench testing. I can see putting pulses into it does move the lock rod in and out, and the old actuator does respond to lock/unlock pulses as well so it was probably ok. At a bit of a loss what to do next... will have to put it back together in the morning and see if the rod still moves when not on the manual lock switch. The manual lock switch does work, but maybe there's an issue with it sticking/stiff and not enough torque electrically.
    Also, side note - where the actuator connects to the door lock plate there is a small partial gear (like 1/4 circle), not sure what it's for - it's there a best way these should be mated? Can see it here:
    http://shop.advanceautoparts.com/wcs...7_pri_larg.jpg
    It can go to the far left or right and only have a tooth or two exposed
  9. #9 Re: Door unlocks but doesn't lock
    Oct 2013
    WI
    I just took another quick look at the manual lock switch and it's freely moving and I don't think that's the cause - for some reason I thought there was a spring or something. Completely out of ideas now
  10. #10 Re: Door unlocks but doesn't lock
    Omaha, NE
    Here are the diagnostic procedures for an inoperable driver door lock as featured on AllData for an 04 GT2.
  11. #11 Re: Door unlocks but doesn't lock
    Oct 2013
    WI
    An update ... re-installed it, didn't work but as expected since I believe the old actuator was ok (used new one) and all I really did was lubricate it. One bit of new info - I was able to make my own connector so I could power the actuator directly via a 12v power supply will in the door, and the door does lock when pulsed via the external source. I do see a pulse though on the factory connector, though it's hard to read on a meter since it's so quick. I wish when I was using my custom connector I would have tried swapping wires and see if the unlock signal I know works would lock the door and vice versa. Probably will leave it for a while.
    One a side note for future reference it did seem the gear position matters, it's used by the door ajar sensor and does open/short based on the position. I used this image from a youtube video setting the lock and gears in the same position and verified it worked on a meter moving the door latch manually
  12. #12 Re: Door unlocks but doesn't lock
    Oct 2013
    WI
    Final update for future reference, I've gotten it fixed. Even though I was showing an unlock pulse at the actuator on a meter and test light, something was up with wiring - perhaps enough amperage couldn't get through? I connected by extra lock actuator directly to the BCM under the dash (A/Tan & C/Gray) and it worked, so I ran two new wires from the BCM through the door to the actuator and used taps on each end so I still had the factory wiring connected.
  1. Door Lock Actuator Replace - Now doors won't electronically lock
    By rmortime in forum General Tech Discussion
    Last Post: 11-17-2012, 12:37 AM
  2. Cant' lock door.
    By Cenon in forum Audio, Security & Visual Electronics
    Last Post: 01-16-2012, 08:33 PM
  3. door lock help
    By dudleyc05 in forum General Tech Discussion
    Last Post: 01-29-2011, 05:29 PM
  4. 2006 Pontiac Grand Prix Driver door lock doesn't unlock
    By PianoMan99 in forum General Tech Discussion
    Last Post: 09-23-2009, 06:22 AM
  5. remote door lock horn only when lock ?
    By NEONNIGHT34609 in forum General Tech Discussion
    Last Post: 12-10-2008, 09:05 PM
