Thread: Need Help!!!!
Results 1 to 5 of 5
  1. #1 Need Help!!!!
    Sep 2013
    chatsworth, il
    I have a 99gt. Went to throw on my left blinker the other day and it was blinking all crazy like. Figured out that the rear blinker wasn't working. Also, went to use my right blinker navigating through traffic and as soon as the blinker came on, my cruise shut off. This whole ordeal comes and goes...any ideas??
  2. #2 Re: Need Help!!!!
    May 2012
    Albuquerque, NM
    Start by checking your bulbs. An idea that comes to mind is that if your blinker and break are on the same bulb, your break light sensor and cruise control are connected, there's the connection. So your blinker is shorting and activating the break light sensor, which deactivates the cruise control. That's where I'd start.
  3. #3 Re: Need Help!!!!
    Could be the multifunction switch going bad.
  4. #4 Re: Need Help!!!!
    Sep 2013
    chatsworth, il
    Thanks guys! Ended up being a screwy connection at the bulb. Hit it with some electrical grease and solved the problem.
  5. #5 Re: Need Help!!!!
    GTX Level Member SnowTh1ef's Avatar
    Aug 2013
    Sandy, UT
    Make sure your blinker fluid is full as well
    04 GTP -HAI, 1.9 rockers.
