Thread: 04 Grand Prix GTP hesitation/bucking
Results 1 to 16 of 16
  1. #1 04 Grand Prix GTP hesitation/bucking
    May 2013
    kansas
    Guys im really needing some help. I have an 04 GTP, when Im on the HWY cruising 65 when i start to go up hill the car starts to hesitate and has a bucking feeling. It will also do the same thing if Im cruising @ 45MPH and slightly accelerate. The car has 75K miles on it. I have changed the transmission fluid and filter but is still doing the same thing. I understand that this topic a fairly common problem. So if anyone has the solution to fix this problem I would greatly appreciate your imput. Thanks
  2. #2 Re: 04 Grand Prix GTP hesitation/bucking
    Cel on? Try plugs and wires and clean your maf
  3. #3 Re: 04 Grand Prix GTP hesitation/bucking
    May 2013
    kansas
    What do you mean cel on?
  4. #4 Re: 04 Grand Prix GTP hesitation/bucking
    "Check Engine Light"
  5. #5 Re: 04 Grand Prix GTP hesitation/bucking
    May 2013
    kansas
    no its never been on
  6. #6 Re: 04 Grand Prix GTP hesitation/bucking
    GT Level Member primem's Avatar
    Sep 2013
    Calgary, Alberta
    Quote Originally Posted by TMBT1989 View Post
    the tcc will come out of full lock up at during the conditions you describe, it may be shuddering at it pulse width modulates out of full lock. This will not set any dtc's.
    does it go away when you accelerate harder?
    2004 comp g
  7. #7 Re: 04 Grand Prix GTP hesitation/bucking
    Aug 2011
    'Merica
    have you ever had it scanned?
  8. #8 Re: 04 Grand Prix GTP hesitation/bucking
    May 2013
    kansas
    No i haven't had it scanned. Im looking for someone that is having the same problem as I am. I have read forums and forums over this topic but no one really said what they did to fix the problem.. Also its not a constant problem. It may do it a couple times a week, then not do it for a week or so. Its very strange.
  9. #9 Re: 04 Grand Prix GTP hesitation/bucking
    Aug 2011
    'Merica
    i would go have it scanned at your local auto parts store to see if it is throwing any codes
  10. #10 Re: 04 Grand Prix GTP hesitation/bucking
    May 2013
    kansas
    Thanks for the help!
  11. #11 Re: 04 Grand Prix GTP hesitation/bucking
    Aug 2011
    'Merica
    Knowing what the codes are (if any) will help us out a little bit more. Have you tried cleaning your MAF and your TB? If not, when you are there having it scanned, buy some TB cleaner and MAF cleaner. TB will look clean but it will be filty on the inside if it has never been cleaned before.
  12. #12 Re: 04 Grand Prix GTP hesitation/bucking
    Sounds like a mass air flow sensor issue. Clean it and also clean the throttle body while you're at it.
  13. #13 Re: 04 Grand Prix GTP hesitation/bucking
    Apr 2012
    Windsor
    sounds a bit off from what i had, you can read my horrible story here
    http://www.grandprixforums.net/showthread.php?t=67871
    Coming from someone who went down this long expensive road if i were you i would clean the MAF, see if it helps. If its still there you can try replacing the MAF, otherwise maybe try the PCM update that fixed my car, you can have it done at any GM dealership and its under $100
    Quote from my thread
    "FINALLY FIXED So after close to 6 months of dealing with this issue its finally gone. spending over $4000 on sensor changes and any other "guess" to what it could be, plus a full transmission rebuild...turns out the problem was the TCC sticking which was corrected by a simple PCM upgrade. Reference number 04-06-04-078, Anyone with similar issues just drive down to your gm dealer and get them to check for any updates for your PCM and put them in. If you go to a transmission shop like i did, you might end up paying for a rebuild you probably did not need."
  14. #14 Re: 04 Grand Prix GTP hesitation/bucking
    May 2013
    kansas
    Yes when i accelerate hard its fine. It will do it when im cruising at 45 mph and 65 on the highway. It only happens when I lightly accelerate. At hard throttle its fine..
  15. #15 Re: 04 Grand Prix GTP hesitation/bucking
    Buffalo NY
    My 07 has been kinda doing that since when I bought it new... its only a 4 speed transmission... usually when your in 4th going up a hill..eventually it down shifts on its own to increase the power.. usually I just give it more gas before it does this.. seems quite common even in a car that has been babied from day one.
  16. #16 Re: 04 Grand Prix GTP hesitation/bucking
    Sep 2013
    Calgary, Alberta
    there no mistaking a tcc shudder and a delayed downshift. the shudder can occur more than once
    2004 comp g
  1. bucking gtp
    By maxxbet in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 04-17-2013, 03:39 PM
  2. Help 04 Grand Prix stutter hesitation bucking wtf???
    By intrinity in forum General Tech Discussion
    Last Post: 09-08-2012, 11:49 PM
  3. 2000 Grand Prix GT Intermittent Hesitation and Stalling
    By scottyfl813 in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 05-21-2012, 04:45 PM
  4. miss firing and bucking
    By mattmc99 in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 07-15-2011, 12:36 AM
  5. Strange Stalling/Bucking
    By Moribound in forum General Tech Discussion
    Last Post: 11-17-2010, 04:26 PM
