Thread: Radiator pressure test 04 GTP
Results 1 to 6 of 6
  1. #1 Radiator pressure test 04 GTP
    Oct 2008
    UT.
    Losing coolant but can't find the problem. Picked up a pressure tester but when I try to pump it up the air escapes through the recovery tank without any resistance. Are you supposed to pinch off that line to bypass it? The tank and radiator are both at their correct levels. What am I doing wrong? 2004 Grand Prix GTP with CompG.
  2. #2 Re: Radiator pressure test 04 GTP
    seems like the pumps not seating right. is there a different cap part you can use with the tester?
  3. #3 Re: Radiator pressure test 04 GTP
    Oct 2008
    UT.
    I have the adaptor for the screw on radiator cap but that is all there is.
    If I pinch off the bypass hose pressure will start to build.
  4. #4 Re: Radiator pressure test 04 GTP
    pinch it off, or a bolt and hose clamp should seal it good. never heard of this tho, it should seal off tight.
  5. #5 Re: Radiator pressure test 04 GTP
    Oct 2008
    UT.
    I'll be trying that in the morning.
    Thanks for the reply.
  6. #6 Re: Radiator pressure test 04 GTP
    Feb 2013
    37.295091, -121.930053
    Also keep in mind that the pressure should hold perfectly still once you stop pumping it up. It should hold pressure perfectly forever but I would hold it for 5 mins.
    im a cookie again yay me
    please learn to forum better.
    ^^new favorite quote
  1. Cooling system pressure test
    By BlackGT97 in forum General Tech Discussion
    Last Post: 08-15-2011, 02:41 PM
  2. 2001 GTP - Transmission fluid pressure at radiator?
    By RealtyCaffeine in forum General Tech Discussion
    Last Post: 11-14-2010, 06:21 PM
  3. test radiator fan
    By mhartwig in forum 3.1L V6 (LHO/LG8)
    Last Post: 10-09-2010, 02:53 AM
  4. P1811 and line pressure test
    By explokid in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 07-13-2010, 10:56 PM
  5. What size is the fuel pressure test port?
    By alacran in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 05-10-2008, 08:27 AM
