Heat won't matter if he's righty loosey, lefty tightying things.
Trick for you. Hold your ratchet in front of you.. with your hand on the socket, turn it to ensure it's moving in the correct direction. Doesn't matter if you are upside down and backwards working on a car. If you do that. You should never be able to "reverse loosen" a bolt.
