with the car in park and the key in run; check for voltage on the yellow wire at the ignition switch. should be 0volts, leave the meter connected for a while because the voltage leakage is intermitant. The bad switch I tested has voltage leaking through and the voltage varied from 0, then up to 9volts back to 5v etc.
