well i decided to check out my engine and look around to see if there was any issues that i could see and long behold i see a nice puddle of coolant by the injectors.after further inspection its coming from the center supercharger bolt channel directly in front of the middle injector.
so after cleaning it and finding the middle channel supercharger bolt not tightened i decided to check today. after checking today i see a tiny amount so its still leaking.
so now its time for troubleshooting.
i had just replaced my supercharger gasket a few weeks back so im guessing somewhere within the weeks something changed.
also i noticed to gasket hangs by the first injector closest to the coil packs. should it? ill snap a pic and also can i just remove that one bolt and apply some red threadlocker?
i know it could be the manifold gaskets but it seems odd for it to fail that quickly out the blue. never had a leak until i removed the charger. thoughts?
this pic shows the overlap of the gasket.
