Thread: so apparently my car decided to puke.
Results 1 to 18 of 18
  1. #1 so apparently my car decided to puke.
    Dec 2010
    DMV
    well i decided to check out my engine and look around to see if there was any issues that i could see and long behold i see a nice puddle of coolant by the injectors. after further inspection its coming from the center supercharger bolt channel directly in front of the middle injector.
    so after cleaning it and finding the middle channel supercharger bolt not tightened i decided to check today. after checking today i see a tiny amount so its still leaking.
    so now its time for troubleshooting.
    i had just replaced my supercharger gasket a few weeks back so im guessing somewhere within the weeks something changed.
    also i noticed to gasket hangs by the first injector closest to the coil packs. should it? ill snap a pic and also can i just remove that one bolt and apply some red threadlocker?
    i know it could be the manifold gaskets but it seems odd for it to fail that quickly out the blue. never had a leak until i removed the charger. thoughts?
    this pic shows the overlap of the gasket.
  2. #2 Re: so apparently my car decided to puke.
    Gasket looks normal.
  3. #3 Re: so apparently my car decided to puke.
    Dec 2010
    DMV
    so apparently i did something wrong or i got a crappy gasket, also should i use gasket sealer? for the supercharger gasket?
  4. #4 Re: so apparently my car decided to puke.
    I said it looks normal because there is overhang. Why would you need to seal anything?
  5. #5 Re: so apparently my car decided to puke.
    Dec 2010
    DMV
    oh because im going to remove the charger in the morning to investigate and i have to replace the plenum gasket so i was wondering should i use gasket sealer. i know i should go ahead and do the manifold since im so close but money is tight lol. damn you sallie mae
  6. #6 Re: so apparently my car decided to puke.
    I live here. TLSheff's Avatar
    Make sure you replace the little yellow o-rings, that's where the coolant comes through to the throttlebody. If you don't use new o-rings it will spray coolant and that could be part of the issue. I would pull the gasket, replace the supercharger gasket, those o-rings, and clean both surfaces perfectly and then put it back together. Should fix it unless there is crack somewhere.
  7. #7 Re: so apparently my car decided to puke.
    Dec 2010
    DMV
    ok thanks, ill start in the morning.
  8. #8 Re: so apparently my car decided to puke.
    Feb 2013
    37.295091, -121.930053
    umm your valve cover has a small crack in it.
    im a cookie again yay me
    please learn to forum better.
    ^^new favorite quote
  9. #9 Re: so apparently my car decided to puke.
    Dec 2010
    DMV
    after thinking back...... i rembered something. not one time did i look at the supercharger to see if there was gasket still stuck to it. smh. but why the massive coolant leak all of a sudden. its been fine for quite awhile. thats whats confusing me.
  10. #10 Re: so apparently my car decided to puke.
    Dec 2010
    DMV
    I mean I pulled off what was on the manifold but I didn't look at the bottom of the Supercharger
  11. #11 Re: so apparently my car decided to puke.
    Feb 2013
    if you had a gasket there it would have stuck to one side or riped in half. so it looks like the last person to touch it didnt put one on. how cheap can you be.
    EDIT: not meaning you the other person who fixed it
  12. #12 Re: so apparently my car decided to puke.
    Need to double check that when you tear it off. and get some Scotchbrite pads and surface sand it so its nice and clean on both the manifold and supercharger where the gaskets meet. If there is anything there it will result in either an air leak, or coolant leak, depending. But it is possible it took a bit to leak because was almost sealed but finally worked its way out.
    Just make sure both surfaces are flat and smooth and use new GM/Felpro gaskets and you should be good to go.
  13. #13 Re: so apparently my car decided to puke.
    Feb 2013
    like in this picture
  14. #14 Re: so apparently my car decided to puke.
    Dec 2010
    DMV
    Success! After two tries lol. Had old gasket on the charger. Here's a few pics
    All done
  15. #15 Re: so apparently my car decided to puke.
    Good Job!
    That small spot being that close to the o-ring was definitely a problem. Took thick to seal with a "double gasket" area like that, especially that close to the o-ring. Glad it was an easy fix.
  16. #16 Re: so apparently my car decided to puke.
    Dec 2010
    DMV
    Thanks man, was happy to have it fixed. Got frustrated but remembered to walk away before I break something lol
    Sent from my HTC One using Tapatalk 2
  17. #17 Re: so apparently my car decided to puke.
    GTP Level Member tms8582's Avatar
    Washington Michigan
    Nice looking engine bay. I like the gold color.... it even looks good on the throttle body which surprises me because I usually think throttle bodies look horrible painted the same color as the super charger.
    Stage 1 Comp Cam / 105 Springs / Yella Terra 1.7's / SLP Headers / Ported heads / 255 Walbro fuel pump / Siemans 60# Injectors / 2.8 Pulley / 180 stat, 104 AL's / Intense e85 tune / 3" ZZP exhaust / GXP seats / KYB Coilovers /
  18. #18 Re: so apparently my car decided to puke.
    Dec 2010
    DMV
    Thanks man. Appreciate it.
  1. Apparently, this blue guy...
    Last Post: 09-18-2011, 08:55 PM
  2. maf sensor....i can take it apart apparently?
    By Couch in forum General Tech Discussion
    Last Post: 08-25-2011, 05:49 PM
  3. Thought i had to puke... warning:not for weak stomachs and women.
    By AmericanRiceEater in forum The Rant Forum
    Last Post: 08-14-2010, 09:59 PM
  4. So apparently....
    By SlowM90 in forum Track Sessions and Kills
    Last Post: 07-21-2009, 06:04 PM
