check the wires to the maf's plug, look for cracks or missing insulation, if the wires are damaged in any way it car cause the maf code to pop up.
if you do need a new pig tail, make sure you solder the new one on or the same problems will happen again down the road.
what code are you getting? the one that says low voltage?
