Thread: Thinking of converting to E85.. Yes or Ne??
Results 1 to 20 of 224
  1. #1 Re: Thinking of converting to E85.. Yes or Ne??
    Banned
    CT
    Quote Originally Posted by Ginseng View Post
    Again im just trying to understand this. The timing retard programmed in the pcm during shifts is torque management to save the trans life not to combat knock?. But does or doesnt show on a scan gauge as actually kr? If it did i imagine everyone would see kr during shifts but not everyone does. But i thought the scan gauges read timing retarded in degrees to combat knock. Now is kr on a gauge reading retard only during actually knock or false knock? or is it reading the actual knock or false knock thats accuring in degrees? Now its possible gm programmed that retard to combat knock that is more probable during shifts.
    Edit: So if we took those values of what bill posted and set to zero would the car be more prone to knock or would it just put for stress on the tranny?
    What Bill is saying is confusing an issue that really isn't even an issue.
    The torque management system is just that... torque management. It has nothing to do with knock.
    KR is either knock, or something else making noise that falls within the frequency range of knock.
    This is 3800 101 here.
    I'm sorry you guys are being confused by Bill.
    This is a decent write up that seems relevant.
    http://www.zzperformance.com/blog/ab...ock-retard-kr/
  2. #2 Re: Thinking of converting to E85.. Yes or Ne??
    gardner,mass
    Detonation: Detonation is the spontaneous combustion of the end-gas (remaining fuel/air mixture) in the chamber. It always occurs after normal combustion is initiated by the spark plug. The initial combustion at the spark plug is followed by a normal combustion burn. For some reason, likely heat and pressure, the end gas in the chamber spontaneously combusts. The key point here is that detonation occurs after you have initiated the normal combustion with the spark plug.
    Pre-ignition: Pre-ignition is defined as the ignition of the mixture prior to the spark plug firing. Anytime something causes the mixture in the chamber to ignite prior to the spark plug event it is classified as pre-ignition. The two are completely different and abnormal phenomenon.
    RPF1 17x9 255/45 Direzza Zll
    04 COMPG- Vs, getrag 284 RIP
  3. #3 Re: Thinking of converting to E85.. Yes or Ne??
    Banned
    CT
    Exactly... and neither of these phenomenon have anything to do with torque management and vice versa.
  4. #4 Re: Thinking of converting to E85.. Yes or Ne??
    gardner,mass
    Quote Originally Posted by SnowFlake View Post
    Thought ide point that out cus in that zzp article he said the overlap on his headgasket causing a hotspot and thus causing detonation when in fact it would actually be pre-ignition.
  1. converting
    By cmn36 in forum General Tech Discussion
    Last Post: 01-15-2011, 07:18 PM
  2. converting a 01 to an 04
    By sasquatch094 in forum General Tech Discussion
    Last Post: 03-25-2010, 05:22 PM
  3. Converting to supercharged
    By Bechtel88 in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 03-23-2010, 09:31 AM
  4. question on converting.
    By gt42lst in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 10-12-2009, 11:54 AM
  5. Converting from a 1 bar to a 2 bar map.
    By TurboKent in forum General Tech Discussion
    Last Post: 03-16-2008, 02:10 PM
