Thread: to all who have ever had low oil level light come on...
Results 1 to 7 of 7
  1. #1 to all who have ever had low oil level light come on...
    Sep 2013
    Frederick,MD
    i know this might sound stupid but def check the wiring from the sensor on the oil pan all the way to the harness.mine was recently chewed through by mice i guess? also have had the neighbor complain of the same issue on his monte carlo...his were chewed about 15 inches away from the sensor.mine were chewed right at the sensor...go figure...must be tasty wire?
  2. #2 Re: to all who have ever had low oil level light come on...
    zip tie some rat poison under your car. that will fix your wire eating critter problems.
  3. #3 Re: to all who have ever had low oil level light come on...
    Sep 2013
    Frederick,MD
    i was just in another forum i used to belong to and several folks have the same problem! i dont understand why they like these wires so much? maybe cause they are pretty low to the ground?
  4. #4 Re: to all who have ever had low oil level light come on...
    mice and rats can chew through almost anything. if a car sits long enough, they make a home out of it. air filter boxes are a favorite home lol
    my cars last owner was from newark NJ, there was rat poison zip tied all over the engine bay.
  5. #5 Re: to all who have ever had low oil level light come on...
    Mercer, Pa
    Don't no how true, but I have heard that electrical wire insulation now has peanut oil in it.
  6. #6 Re: to all who have ever had low oil level light come on...
    GT Level Member primem's Avatar
    Sep 2013
    Calgary, Alberta
    I have seen a car will teeth marks all over the underbody. owner believes it was porcupines eating the rustproofing that was applied to the car. they chewed everything rubber also, which left a big holes in the fuel filler neck. The owner had us zip tie tin foil to every rubber hose on the fuel tank and evap lines. Don't know if it worked.
  7. #7 Re: to all who have ever had low oil level light come on...
    Jan 1970
    Maquoketa, Iowa
    I've had the oil level sensor unplugged for years now and the light comes on maybe once every 10 times I drive it.
  1. Low Oil Level Light Still Comes On After Low Oil Level Sensor Replacement
    By LoveMyGPGT in forum General Tech Discussion
    Last Post: 04-23-2017, 09:20 AM
  2. Low oil level light
    By 1slo03GT in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 05-12-2012, 03:19 PM
  3. Low oil level AND oil pressure light
    By davidw in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 10-26-2011, 09:09 AM
  4. Phantom, intermittent LOW COOLANT LEVEl light, + other fun stuff
    By EricR in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 10-14-2011, 03:26 PM
  5. Oil Level Light problem likely the sending unit?
    By pur3vil in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 03-22-2011, 08:48 AM
