Thread: Low oil level light
Results 1 to 6 of 6
  1. #1 Low oil level light
    SE Level Member 1slo03GT's Avatar
    Apr 2012
    Holland, MI
    Hey guys,
    I've ran into what I hope to be a small problem with my car. Every so often the low oil level light comes on. I can guarantee you the car isn't low on oil and I change it regularly, if not early. Once the car warms up and I shut it off for 30 seconds or so, then restart it, the light turns off. Any ideas as to what may be causing this? It's a stock '03 L36 that just rolled 149K miles. It's frustrating me to no end and I really want to figure out what's going on.
    Any help or guidance is greatly appreciated! Thanks!
    [under construction] 03 GT = WAY too stock. Needs more low...
  2. #2 Re: Low oil level light
    Check the sensor, see if its loose, check the connector, clean the connector if needed.
    The sensor itself may be bad or even a partly broken wire. Could be many things.
  3. #3 Re: Low oil level light
    Slap a new sensor in if the electrical is all good. Then smile as you drive another 150K on it.
  4. #4 Re: Low oil level light
    Grand Island, Nebraska
    JSYK, if you unplug the sensor, the light doesnt turn on. Maybe if it shorted somewhere it might turn on, but I have mine unplugged for my oil pressure gauge and theres no light.
  5. #5 Re: Low oil level light
    Quote Originally Posted by JoRoW99 View Post
    Interesting how do you have the level sensor on the front of the pan unplugged for the pressure sensor that is located on the back of the motor on the oil filter adapter?
  6. #6 Re: Low oil level light
    I see my mistake. I was talking about the oil pressure sensor dummy light, its by the filler neck. Didnt know there was a low level sensor also.
  1. Low Oil Level Light Still Comes On After Low Oil Level Sensor Replacement
    By LoveMyGPGT in forum General Tech Discussion
    Last Post: 04-23-2017, 09:20 AM
  2. Low oil level AND oil pressure light
    By davidw in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 10-26-2011, 09:09 AM
  3. Phantom, intermittent LOW COOLANT LEVEl light, + other fun stuff
    By EricR in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 10-14-2011, 03:26 PM
  4. Oil Level Light problem likely the sending unit?
    By pur3vil in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 03-22-2011, 08:48 AM
  5. Replies: 16
    Last Post: 01-23-2010, 09:43 AM
