Thread: Fuel pump rewire issues
Results 1 to 6 of 6
  1. #1 Fuel pump rewire issues
    The Boss Iceman6669's Avatar
    Jun 2011
    So I bought my rewire and was changing my pump. Found out I had the wrong plug on the pump.
    So my question is...
    Is it possible to rewire a fuel pump without buying a rewire kit? Like snip the hot at the plug and splice in a thicker wire and run it to the alt?
    2011 F-150 Yote powered
  2. #2 Re: Fuel pump rewire issues
    Portland Oregon
    You would want to run it from the plug at the pump to the relay in the relay box supplying voltage to the pump
  3. #3 Re: Fuel pump rewire issues
    GTX Level Member dbextreme's Avatar
    Nov 2009
    Tennessee
    Might be a stupid question, but if he did this wouldn't he need to upgrade the other side of the relay wiring? Whatever is powering the relay will still be the small gauge wire.
    You can make your own "harness" yourself just use the bought harness as a guide and make your own plug at the pump?? Time to test your electrical skills
    1999 GPGT - L26, Ported Top Swap, XP Cam, 3.2 MPS, 42.5#, N*, LQ4, SD Headers, Double Roller, TEP Race Trans w/Stand alone Cooler, Precision Industries 3000RPM Stall, 75 Shot Nitrous Express Proton Kit w/Purge, 3" Dual Borla Pro XS, Corsa Dual 3.5 Tips, 5% Tint
    1995 Firebird Formula - Under the Knife
  4. #4 Re: Fuel pump rewire issues
    Jun 2011
    I wired the pump with heavier gauge wiring right to the relay. Which is at the fuse box under the hood.
  5. #5 Re: Fuel pump rewire issues
    What year is your car? I've yet to see a plug like that.
  6. #6 Re: Fuel pump rewire issues
    Jun 2011
    Mine is a 97... From what I can gather it is an aftermarket replacement pump.
  1. 97 GTP fuel pump woes: Rewire stock pump?
    By Powertrike in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 05-09-2013, 06:29 PM
  2. wtb fuel pump rewire
    By srt4vsgtp in forum Wanted To Buy - Parts
    Last Post: 02-13-2013, 09:06 AM
  3. zzp fuel pump rewire
    By Hawkman in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 09-02-2012, 12:59 PM
