Well I'm contemplating a top swap on the 04 GP GTP. Basically, I can find a N/A motor from the same year or newer, with low miles for a pretty good price. About a third of what I can find a S/C version used for. The motor I have has a slight knock in the bottom end. I'm trying to put together a list of what parts I will need to complete the swap. Please let me know if this is correct.
Head Gaskets
head Bolts/studs
LIM Gasket
UIM Gasket
Valve Cover Gaskets
PCM Tune
From what I have read, the bottom end and con rods are the same between the L26 and L32, with the L26 having a higher comp ratio. Please add to this list as I am going to start gathering parts for this. I already have the LIM and UIM Gaskets.
thanks,
matt
