Thread: Contemplating Top Swap
Results 1 to 20 of 24
  1. #1 Contemplating Top Swap
    GT Level Member orange57's Avatar
    Aug 2012
    Chandler, AZ
    Well I'm contemplating a top swap on the 04 GP GTP. Basically, I can find a N/A motor from the same year or newer, with low miles for a pretty good price. About a third of what I can find a S/C version used for. The motor I have has a slight knock in the bottom end. I'm trying to put together a list of what parts I will need to complete the swap. Please let me know if this is correct.
    Head Gaskets
    head Bolts/studs
    LIM Gasket
    UIM Gasket
    Valve Cover Gaskets
    PCM Tune
    From what I have read, the bottom end and con rods are the same between the L26 and L32, with the L26 having a higher comp ratio. Please add to this list as I am going to start gathering parts for this. I already have the LIM and UIM Gaskets.
    thanks,
    matt
    matt
    2004 Grand Prix GTP - work in progress
  2. #2 Re: Contemplating Top Swap
    May 2012
    Cedar Rapids, Iowa
  3. #3 Re: Contemplating Top Swap
    Aug 2012
    Chandler, AZ
    excellent. Thank you sir.
    matt
  4. #4 Re: Contemplating Top Swap
    Aug 2012
    Chandler, AZ
    Where does one get rocker bolts? Does ARP make them? Anyone have any part numbers?
    I think I may go with the ARP Stud Kit for the heads for this, and may order the rocker bolts at the same time if they make them.
    matt
  5. #5 Re: Contemplating Top Swap
    Comp cam reusable rocker bolts...just about every vendor sells them ZZP, intense, Wbody store etc
    04 Comp G.
  6. #6 Re: Contemplating Top Swap
    Aug 2012
    Chandler, AZ
    Excellent. Adding to the shopping list...
    matt
  7. #7 Re: Contemplating Top Swap
    I Write E85 Stickies Frosty's Avatar
    Apr 2011
    South Dakota
    Honestly get zzps top swap gasket kit, it has EVERYTHING. Also dont try to run a 3.8 pulley on the high compression without headers or e85. Be aware your injector connectors might be wrong. If you want to avoid having to run the dual belt setup you can run ZZPs ssm90 pulley all the way down to a 3.4. Also be aware that a stock supercharged pcm will require a 2 bar map sensor. In your case just buy a 2004+ gtp sensor. Also I recommend all 97+ top swaps run a 2004+ map sensor as well because they are plug and play without cutting wires. Another thing to remember is you dont need the boost bypass solinoid so I wouldent bother adding the wiring. Just tune the boost solinoid check engine light out. Also while you have the heads out its the perfect time to do valve seals at least if not springs as well so you can shift nice and high. Only takes a hour or two with the heads off the car.
    I have done 3 top swaps so far so I have hit all of the stumbling blocks at least once. In fact here is the most recent one I helped with.
    http://www.grandprixforums.net/topsw...ild-82238.html
    "Lets just throw more boost at it and see what happens" -Frosty
    The Defacto Guide to tuning your car for E85. Read it and learn.
    I love Decker<3
  8. #8 Re: Contemplating Top Swap
    Yea get headers forsure
    04 Comp G.
  9. #9 Re: Contemplating Top Swap
    Aug 2012
    Chandler, AZ
    Frosty,
    Thanks for the tips. I actually have all the parts listed in the kit already except the Head bolts, Rocker Bolts and Head Gaskets, as I was planning on doing the LIM on the car.
    I have an 04 GTP and have a slight knock. However, locally, a S/C 3.8 start out at around $1300, and all have 100K plus on them. I can get a 04+ N/A with 10K to 50K miles on it for around $400-700. So that is the reason that I am looking to top swap. I would have all the parts from the GTP and use the N/A, swap everything over and swamp the motor out.
    I guess I will have to see if I can find some headers as well. Don't want to blow the engine right after a swap.
    matt
  10. #10 Re: Contemplating Top Swap
    Apr 2011
    South Dakota
    I doubt you would blow it considering stock engines can have 8+ degrees of kr and drive every day without issues. You have to worry when your running something silly like the 2.8" pulley I have. If I kr I could chunk a piston quickly.
    I love Decker<3
  11. #11 Re: Contemplating Top Swap
    Aug 2012
    Chandler, AZ
    i am wanting to run everything stock for now, basically just a short block swap. will headers be necessary? or can that mod come down the line? the GTP has a MPS with the 3.8 pulley on it now. If headers arent necessary i'd like to hold off, as i really just need the car driveable, not a performance machine right now.
  12. #12 Re: Contemplating Top Swap
    GTX Level Member SnowTh1ef's Avatar
    Aug 2013
    Sandy, UT
    Quote Originally Posted by frosty View Post
    Hey! that's my build! haha, but yes, Comp cams reusable rocker bolts were great and plus one to everything else these guys Said, and I'd highly recommend headers or e85
    04 GTP -HAI, 1.9 rockers.
  13. #13 Re: Contemplating Top Swap
    Aug 2013
    Sandy, UT
    if you already have a mps and don't want to do headers go up to at Least a 4" pulley if not 4.2" because You will hit KR much easier
  14. #14 Re: Contemplating Top Swap
    Aug 2012
    Chandler, AZ
    i dont think i saw anything bigger than a 3.8 on zzp. either way, i need to get the engine and do most of the swap work first. I am leaning towards headers instead of a bigger pulley. it will be a while before I am at that point, as i dont have a lot of free time, so the swap will be done slowly.
  15. #15 Re: Contemplating Top Swap
    Banned
    CT
    Get a cam (XP or S1x) instead of headers.
  16. #16 Re: Contemplating Top Swap
    Aug 2013
    Sandy, UT
    ^^ This is a much better idea. Especially since the motor will be out of the car, shouldn't be bad at all
  17. #17 Re: Contemplating Top Swap
    Aug 2012
    Chandler, AZ
    You guys may be a bad influence on me. Too many choices. So if I think about it....a S/C 3800 would cost me somewhere around $1300 ish, with higher miles. I think I may be able to do a top swap with a low mile N/A engine, and get a cam and headers and make a descent amount of power.....need to clear the work bench off in the garage.
    matt
  18. #18 Re: Contemplating Top Swap
    Aug 2013
    Sandy, UT
    sounds like a great plan! I approve haha.
  19. #19 Re: Contemplating Top Swap
    GTX Level Member dbextreme's Avatar
    Nov 2009
    Tennessee
    Quote Originally Posted by orange57 View Post
    I did, see my sig... and so far my best time in the 1/8th mile is 8.7@83 with still tire spin off the line giving crappy 60' times... My L26 motor was very low mileage, like 17K, and only cost me $500. I have a thread that shows the inside of it when I tore it down for the swap. Clean as clean can be..
    1999 GPGT - L26, Ported Top Swap, XP Cam, 3.2 MPS, 42.5#, N*, LQ4, SD Headers, Double Roller, TEP Race Trans w/Stand alone Cooler, Precision Industries 3000RPM Stall, 75 Shot Nitrous Express Proton Kit w/Purge, 3" Dual Borla Pro XS, Corsa Dual 3.5 Tips, 5% Tint
    1995 Firebird Formula - Under the Knife
  20. #20 Re: Contemplating Top Swap
    Aug 2012
    Chandler, AZ
    db, do you have a link to your thread? This is mostly going to be what happens. I am going to pick up an engine stand this weekend and look to get a low mileage N/A motor next week and start tearing things down.
    matt
  1. Tuning Issues, 04 GT (L32 Swap / Gear Swap)
    By RivMan in forum PCM Tuning
    Last Post: 09-12-2013, 08:37 PM
  2. Contemplating buying HPT pro
    By crbquist in forum PCM Tuning
    Last Post: 11-10-2012, 12:01 PM
  3. Replies: 1
    Last Post: 12-31-2011, 04:55 PM
  4. Fuel gauge dosnt work after wireing harness swap and motor swap
    By guimond47 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 06-02-2011, 06:01 PM
  5. Contemplating Suicide...
    By KawaFord in forum Off Topic Discussion
    Last Post: 05-11-2010, 07:36 AM
