Thread: New bearing, still got C0041
Results 1 to 20 of 21
  1. #1 New bearing, still got C0041
    Canada
    Hi guy's.
    When i have buyed this car, i had the C0041 ( RF Wheel Speed Circuit Range/ Performance ). Sometimes the abs start to pulsate my brake for no reason but the ABS light dont comes on. Sometimes the ABS light turns on without sign.
    I just changed the wheel bearing yesterday and no change. I checked the harness up to the front of the engine where it go into a bigger harness and no sign of corrosion or something else. Where to look now ... I have no idea after all.
    I got 1000 OHM for the new wheel bearing.
    Pontiac Grand Prix 2008 SE.
    Thank in advance !
  2. #2 Re: New bearing, still got C0041
    Unplug the battery for 30 mins and then reconnect?
    04 Comp G.
  3. #3 Re: New bearing, still got C0041
    get it scanned at a shop. there's got to be something thats not right if the abs is pulsing under your foot for no reason.
    most shops charge for a abs scan, but its better then tossing money at a phantom problem.
  4. #4 Re: New bearing, still got C0041
    GT Level Member Seachicken's Avatar
    Jan 2013
    Edmonton, Alberta
    if the signal to the ebcm is cutting out for whatever reason while you are braking, the ebcm is going to think your wheel is locking up
    06 Gxp, Bermuda Blue
    82 K5, Black on 35's
  5. #5 Re: New bearing, still got C0041
    Canada
    Quote Originally Posted by Seachicken View Post
    You think a wire is broken somewhere ? ? Or the EBCM is itself is bad ?
  6. #6 Re: New bearing, still got C0041
    Jan 2013
    Edmonton, Alberta
    im not allowed to upload pics, if you pm me you email I can send you a pic of a sensor cutting out (c0041 from my car),
    signal to the ebcm would drop out at low speeds only, that's why my abs would turn on during braking for me,
    check the connector at the WSS for corrosion, and also make sure it has good contact as you might have to bend the metal out more on the female side, past that check the resistance on both the wires before you shotgun the ebcm which do like to fail,
    side note, you said 08 se. I could be wrong but I thought the only trim levels for that year are Base/Gxp
  7. #7 Re: New bearing, still got C0041
    Canada
    You are right ... My bad. It's a base GP ...
    I will try to bend a bit the metal on the female connector ...but for what i remember, all look good. No rust at all.
  8. #8 Re: New bearing, still got C0041
    Jan 2013
    Edmonton, Alberta
    wont rust usually, might get green or white crustys
  9. #9 Re: New bearing, still got C0041
    GTP Level Member rperry435's Avatar
    Oct 2011
    MI
    Your fix is simple. I've done dozens. A new TWISTED pair of wires needs to go from the ebcm to the wheel bearing connector.
    Sent from my SPH-L710 using Tapatalk 2
    '04 CompG - 3.6MPS - 104s - FWI - TOGS - w/14"SlimFans - SLP RR' s - 180HF Stat - TEP SK - Aluminum Oil Pan - 4thGen ZZP Wires - LS7 Lifters - AeroForce - AEM WB - HPTuners - FBSS Air Ride
    ASE & State Certified Auto Electrical Tech
  10. #10 Re: New bearing, still got C0041
    Oct 2011
    MI
    Here's the harness I usually make for each side.
  11. #11 Re: New bearing, still got C0041
    Jan 2013
    Edmonton, Alberta
    rperry, whats the reason for twisting the wires?, just curious.
  12. #12 Re: New bearing, still got C0041
    Omaha, NE
    When did base models get ABS? My 05 base didn't have ABS.
  13. #13 Re: New bearing, still got C0041
    pretty sure every US made car since the late 90's has abs installed standard by law.
  14. #14 Re: New bearing, still got C0041
    May 2012
    Cedar Rapids, Iowa
    My 05 has abs...
  15. #15 Re: New bearing, still got C0041
    Omaha, NE
    Quote Originally Posted by vandezand View Post
    My 05 has abs...
    And your profile says its a GT...
  16. #16 Re: New bearing, still got C0041
    Oct 2011
    MI
    The signal from the wheel bearing is low voltage ac. It can easily pickup interface and cause issues. Twisting the wires prevents that. They come oem that way some just don't realize this when running new ones and create a new can of worms.
    a different application that runs low voltage ac signal. high end RCAs for aftermarket amps and upper level audio factory systems will also use twisted and shielded wiring for signal to the amp.
  17. #17 Re: New bearing, still got C0041
    Jan 2013
    Edmonton, Alberta
    Quote Originally Posted by rperry435 View Post
    I knew there had to be a reason, thanks man, what do you do on for the connectors, do you repin it at the ebcm and use a whole new one at the wss?
  18. #18 Re: New bearing, still got C0041
    May 2012
    Cedar Rapids, Iowa
    I thought the gt was the base model.
  19. #19 Re: New bearing, still got C0041
    Oct 2011
    MI
    I've seen brand new vehicles without abs. Can't say I've ever heard of a gp without it but I've definitely seen others without but usually base models like a cobalt or malibu for ex.
  20. #20 Re: New bearing, still got C0041
    Oct 2011
    MI
    Not nessesary. Just cut the wires at he ebcm a few inches back. SOLDER them covering it with either high grade electrical tape like super 33+ or shrink tubing. At the wheel bearing you can either cut off the connector soldering the new wires directly to the wheel bearing side (I only say this because I have seen the wire inside the insulation by the plug turn Into powder from oxidation. something someone might not ever see but would prevent the new pair of wires to fix nothing... Mind you this wheel bearing connector showed NO signs of being compromised I've only see this exact scenario once in 10yrs.) or cut the wires back a little from the vehicle side plug and solder there.
  1. Pre- Gen Hub Bearing Questions
    By SpecialEdition01 in forum Brakes/Suspension/Chassis
    Last Post: 07-05-2013, 10:42 AM
  2. wheel bearing hub
    By learnAsUGo in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 07-01-2011, 09:43 AM
  3. Bad main bearing?
    By Teancum in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 02-08-2010, 11:05 AM
  4. maybe bad bearing?
    By mvp2765 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 11-12-2009, 08:26 AM
  5. Rod bearing took a S***
    By speedemongtp in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 06-25-2009, 08:03 AM
