Thread: New bearing, still got C0041
Results 1 to 20 of 21
  1. #1 Re: New bearing, still got C0041
    GTP Level Member rperry435's Avatar
    Oct 2011
    MI
    The signal from the wheel bearing is low voltage ac. It can easily pickup interface and cause issues. Twisting the wires prevents that. They come oem that way some just don't realize this when running new ones and create a new can of worms.
    a different application that runs low voltage ac signal. high end RCAs for aftermarket amps and upper level audio factory systems will also use twisted and shielded wiring for signal to the amp.
    Sent from my SPH-L710 using Tapatalk 2
    '04 CompG - 3.6MPS - 104s - FWI - TOGS - w/14"SlimFans - SLP RR' s - 180HF Stat - TEP SK - Aluminum Oil Pan - 4thGen ZZP Wires - LS7 Lifters - AeroForce - AEM WB - HPTuners - FBSS Air Ride
    ASE & State Certified Auto Electrical Tech
  2. #2 Re: New bearing, still got C0041
    GT Level Member Seachicken's Avatar
    Jan 2013
    Edmonton, Alberta
    Quote Originally Posted by rperry435 View Post
    I knew there had to be a reason, thanks man, what do you do on for the connectors, do you repin it at the ebcm and use a whole new one at the wss?
    06 Gxp, Bermuda Blue
    82 K5, Black on 35's
  1. Pre- Gen Hub Bearing Questions
    By SpecialEdition01 in forum Brakes/Suspension/Chassis
    Last Post: 07-05-2013, 10:42 AM
  2. wheel bearing hub
    By learnAsUGo in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 07-01-2011, 09:43 AM
  3. Bad main bearing?
    By Teancum in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 02-08-2010, 11:05 AM
  4. maybe bad bearing?
    By mvp2765 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 11-12-2009, 08:26 AM
  5. Rod bearing took a S***
    By speedemongtp in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 06-25-2009, 08:03 AM
