Quote Originally Posted by Seachicken View Post
im not allowed to upload pics, if you pm me you email I can send you a pic of a sensor cutting out (c0041 from my car),
signal to the ebcm would drop out at low speeds only, that's why my abs would turn on during braking for me,
check the connector at the WSS for corrosion, and also make sure it has good contact as you might have to bend the metal out more on the female side, past that check the resistance on both the wires before you shotgun the ebcm which do like to fail,
side note, you said 08 se. I could be wrong but I thought the only trim levels for that year are Base/Gxp
You are right ... My bad. It's a base GP ...
I will try to bend a bit the metal on the female connector ...but for what i remember, all look good. No rust at all.
