Thread: Accessory power outlets ( cigarette lighter jacks) stopped working
Results 1 to 9 of 9
  1. #1 Accessory power outlets ( cigarette lighter jacks) stopped working
    Nov 2012
    Tracy, CA
    I have 2004 GTP Comp G... both my power outlets have no power. I thought it was the relay on the passenger side interior fuse panel, so I changed it... Didn't fix it. Manual isnt clear on which fuse these are on.... Anyone know ? Thanks..
  2. #2 Re: Accessory power outlets ( cigarette lighter jacks) stopped working
    GTP Level Member rperry435's Avatar
    Oct 2011
    MI
    Haha. I too have an 04 CompG with cigarette lighters that don't work. I've looked at the wiring diagram and I've pulled the whole center console and checked for power right at the plug into each socket. Something happens to them and they stop working. Only fix is replace the accessory/cigarette lighters themselves with new or go to a junkyard. I haven't been able to figure out why it happened.
    Just check all the fuses underhood and passenger side to be sure none are blown but in my case they just stopped working one day and I haven't bothered to replace them yet mainly because I don't use them (don't smoke and my double din charges my phone)
    Sent from my SPH-L710 using Tapatalk 2
    '04 CompG - 3.6MPS - 104s - FWI - TOGS - w/14"SlimFans - SLP RR' s - 180HF Stat - TEP SK - Aluminum Oil Pan - 4thGen ZZP Wires - LS7 Lifters - AeroForce - AEM WB - HPTuners - FBSS Air Ride
    ASE & State Certified Auto Electrical Tech
  3. #3 Re: Accessory power outlets ( cigarette lighter jacks) stopped working
    Feb 2014
    washington, D.C.
    Quote Originally Posted by rperry435 View Post
    Everybody has lighter problem and i also. Why? they should think about the standard because we all want our product will be more effective in our current generation. So authority should think about it.
  4. #4 Re: Accessory power outlets ( cigarette lighter jacks) stopped working
    before buying a new one, not that they cost a lot, (10 bucks or less) get some 120 grit sand paper and sand the inside of the power port. and the bottom nipple. thats the power part, the outer insides are the ground.
    sanding them cleans up any rust that may be in there keeping it from making good contact.
    you can also use a test light in the power port and check for power.
  5. #5 Re: Accessory power outlets ( cigarette lighter jacks) stopped working
    Also test for power on the backside. Then check fuses etc.
  6. #6 Re: Accessory power outlets ( cigarette lighter jacks) stopped working
    Donating Users
    Aug 2013
    Michigan, USA
    Make sure the connector is plugged in. When i got mine, both lighter and TC button wouldn't work until I found the connector (passenger side, near the top) was unplugged for some reason. Plugged it back together, it's fine.
    If it's plugged in, the socket is probably shot. The lighter socket seems to die easily for some reason.
  7. #7 Re: Accessory power outlets ( cigarette lighter jacks) stopped working
    Nov 2012
    Tracy, CA
    Does anyone know which fuse these accessory plugs actually go to ?
    The owners manual does not show which one.
    Also, do I have to take the console apart to get at them or do they pull out of where they are mounted ?
    Thanks..........
    Quote Originally Posted by genki View Post
  8. #8 Re: Accessory power outlets ( cigarette lighter jacks) stopped working
    in my regal i had to take the console out to remove them, id think the GP is about the same.
    the fuse box door should have a map on it of the fuses.
  9. #9 Re: Accessory power outlets ( cigarette lighter jacks) stopped working
    May 2015
    maryland
    The fuse is under the hood and it is not on the diagram at all. It is the 25 amp fuse in row 8. 2004 GP GTP comp g.
  1. is their a fuse for each cigarette lighter??
    By thag419 in forum General Grand Prix Discussion
    Last Post: 09-08-2012, 07:05 AM
  2. Removing Cigarette Lighter
    By matthew911 in forum Visual/Body Modifications
    Last Post: 12-15-2011, 11:19 PM
  3. Cigarette Lighter 04 Grand Prix GT Please help
    By bjornbjorn in forum Off Topic Discussion
    Last Post: 07-26-2010, 01:06 AM
  4. Cigarette Lighter Fuse
    By matthew911 in forum General Tech Discussion
    Last Post: 04-06-2010, 10:35 PM
  5. Cigarette Lighter Problems
    By missyfisch in forum Audio, Security & Visual Electronics
    Last Post: 10-08-2009, 09:39 AM
