Thread: Lighting Issues
Results 1 to 10 of 10
  1. #1 Lighting Issues
    GT Level Member Xanthous's Avatar
    Apr 2011
    St. Louis
    I just bought this car about a week ago and inherited some issues, not sure if they're connected.
    Trying to get some ideas on where to start, thanks.
    1) Auto headlights do not work
    2) Radio spikes (goes from low to high, not drastically)
    3) HUD is dimmer than it should be
    4) DIC does not light up
    5) Radio screen does not light up
    6) Gear indicator (next to shifter) does not light up
    I need to check fuses, thinking it may be something w/ the ground.
    The dimmer does dim the interior lights.
    Radio button lights do come on.
  2. #2 Re: Lighting Issues
    Dec 2008
    Lawndale, CA
    What year is the car?
  3. #3 Re: Lighting Issues
    Apr 2011
    St. Louis
    Quote Originally Posted by The Guz View Post
    2000
  4. #4 Re: Lighting Issues
    Dec 2008
    Lawndale, CA
    1) Auto headlights do not work - Check the fuse behind the glove box. If it's ok, it oculd be the sensor on the dash.
    2) Radio spikes (goes from low to high, not drastically) - The radio could just be going bad.
    3) HUD is dimmer than it should be - You could try to replace the dimmer switch or you could go ahead and do this http://www.grandprixforums.net/97-03...fix-33998.html
    4) DIC does not light up - The bulbs could be out. You could try swapping some new one's in to see if that's the issue. The bulb size is PC74
    5) Radio screen does not light up - The bulb is probably out. You could replace it with one of these
    96 02 Pontiac Delco Radio Display Bulb Brown Base for 7 Band CD Cassette | eBay
    or do this
    Radio Lamp Repair
  5. #5 Re: Lighting Issues
    SE Level Member transam24's Avatar
    Dec 2011
    NY
    Check all your fuses and circuit breakers for continuity and power first. Theres one fusebox under the hood and one by the glove box.
  6. #6 Re: Lighting Issues
    Apr 2011
    St. Louis
    Okay thanks Guz and Transam, I will start there. I should also mention that the gear indicator next to the shifter also does not light up, something tells me that is connected with the dic and radio and maybe the headlights.
  7. #7 Re: Lighting Issues
    Dec 2012
    Where 4T65E's were born
    Not likely. It's probably just because someone didn't care to fix problems as they occasionally come up, so you're faced with all of them at once.
    Sold.
  8. #8 Re: Lighting Issues
    Apr 2011
    St. Louis
    So I may have found part of the problem. There's the piece at the top of the dash that has "red light, sensor, sensor/black light), what is this called? The sensor/black light is not there. A pic of this piece would also be helpful.
  9. #9 Re: Lighting Issues
    Dec 2008
    Lawndale, CA
    It's the automatic headlight sensor or twilight sentinel sensor.
  10. #10 Re: Lighting Issues
    GTX Level Member AKGTP19's Avatar
    Mar 2013
    Fort Lauderdale, FL
    Ingot some lighting issues, I have LEDs, all in my map, dome, floor, door and trunk, and when I start my car,day or night, the lights will be on the turn to a low dim and won't go off at all while driving, fuse? Sensor in the switch? Help
    1998 GTP Loudmouth
    1999 GTP, Borla Cat Back.....SOLD
  1. Help me with trunk lighting
    By jteske88 in forum Audio, Security & Visual Electronics
    Last Post: 02-28-2013, 01:52 AM
  2. Lighting issues
    By NHRA21 in forum Audio, Security & Visual Electronics
    Last Post: 03-07-2012, 09:52 PM
  3. Help with lighting please
    By sinceregtp in forum Visual/Body Modifications
    Last Post: 04-15-2010, 10:59 PM
  4. LIGHTING for an 04 GTP
    By ne04gtp in forum Shops and Community Heroes
    Last Post: 02-05-2010, 05:49 PM
  5. Lighting issues (again)
    By vailskier3 in forum Audio, Security & Visual Electronics
    Last Post: 09-17-2009, 07:03 AM
