Thread: Official Weight Reduction Thread
Results 1 to 18 of 18
  1. #1 Official Weight Reduction Thread
    Dec 2012
    Where 4T65E's were born
    I know every so often people ask how to reduce the weight of their GP. Well it's not really the easiest thing to do and have great results, but there are still a few things you can do that will help a bit. Might as well have a master list all in one place for future reference. Some are free, others aren't, and some are plain crazy. I've gathered a list of things I could think of, as well as a few ideas scattered around the site. It is open to suggestions, most will be in the racekar section I'm sure, since that's where you can go pretty far.
    Weight reduction for a DD GP
    Remove:
    Engine cover
    Hood liner
    Firewall liner
    Both engine lift brackets, engine cover bracket, LIM bracket, egr bracket
    Alternator bracket/bar
    Passenger side dogbone mount
    Scrape rust from the underbody
    Spare tire and jack
    Old trans lines(if an independent cooler is installed)
    Hit the gym
    Advanced: (Meaning things must be bought/replaced)
    Run an open cone intake
    Fiberglass/Carbon fiber hood
    Aluminum sub-frame upgrade
    Lighter rims
    Headers/downpipe
    Racing battery
    Swap bumpers for an aluminum from an Aztec/Rendezvous
    Lighter brakes (Grand Am rear brakes)
    Racekar:
    Remove hood shocks
    Remove wiper arms
    Drain the washer fluid
    Remove seats/carpet
    Delete EGR
    Delete HVAC system
    Delete radio, and all speakers
    Delete ABS
    Delete Cruise control
    This list will go on...
    and possibly..
    Weight Relocation:
    Move battery to trunk, run new wire.
    Sold.
  2. #2 Re: Official Weight Reduction Thread
    Waukesha, WI
    go on a diet..
    RayRay
    92 Turbo miata
    71 bagged lemans wagon
    02 lexus is300
  3. #3 Re: Official Weight Reduction Thread
    Howell, NJ
    There is already a thread like this.
  4. #4 Re: Official Weight Reduction Thread
    Dec 2012
    A I mentioned there are lots of threads with ideas scattered around. There was one thread I found that was similar to this (as in the OP listing weight reduction ideas, NOT asking about it), but it's very old and the OP is probably inactive, and unable to keep a running list. Plus right off the bat he's mentioning removing seats wheres I've got it organized in categories so people can find what they're looking for a little easier.
    So basically this is the only active instructive post about it. Don't confuse it with this post http://www.grandprixforums.net/weigh...ghlight=weight
    Sold.
  5. #5 Re: Official Weight Reduction Thread
    Max Cook
    Guest
    You can delete the EGR on a DD. I did. No issues with that if done correctly. I would also not run a race battery like ZZP's on a DD.. and theres definitelly a lot more you can do to reduce racekar weight. I remember on alex's car even when it was already super stripped they still managed to shed another entire 50lbs of weight from just uneeded wiring.
    Also Carbon Fiber Hood > Fiberglass Hood :P
  6. #6 Re: Official Weight Reduction Thread
    Dec 2012
    Hmm well it can be controversial about what section some should be in, as some DD's have plenty of racekar stuff. I suppose it comes down to which state you're in and if it does emissions testing, as well as what you're comfortable with. You and I are in MI, so that would be acceptable. I wouldn't mind deleting my EGR system, especially when I replace my UIM and clean the LIM and don't want it getting all gunked up again. I'd just need to do it "correctly".
    Thanks, I'll add the carbon fiber as an option.
    Sold.
  7. #7 Re: Official Weight Reduction Thread
    The Boss Iceman6669's Avatar
    Jun 2011
    Best way to delete the EGR is to tap and plug the LIM and header/manifold.
    2011 F-150 Yote powered
  8. #8 Re: Official Weight Reduction Thread
    Max Cook
    Guest
    delete EVAP too. also fine on a DD as long as its done right.
  9. #9 Re: Official Weight Reduction Thread
    Dec 2012
    Are there any advantages to that at all?
    Sold.
  10. #10 Re: Official Weight Reduction Thread
    Jun 2011
    Won't leak?
  11. #11 Re: Official Weight Reduction Thread
    Dec 2012
    I wouldn't do it. It basically just makes sure every drop of gas that goes in the tank gets burned. But I suppose it could be another 3 pounds off.
    Sold.
  12. #12 Re: Official Weight Reduction Thread
    Apr 2012
    Goderich, Ontario
    Replace windows and windshield with lexan = racekar
    -Paul Walker
  13. #13 Re: Official Weight Reduction Thread
    GT Level Member dezebe1's Avatar
    May 2013
    Dallas TX
    replace the front crash brace with the Aztek/Rendezvous aluminum brace
    Team JB-Weld
  14. #14 Re: Official Weight Reduction Thread
    gardner,mass
    Im pretty positive the alum oil pan weighs more than the reg one
    RPF1 17x9 255/45 Direzza Zll
    04 COMPG- Vs, getrag 284 RIP
  15. #15 Re: Official Weight Reduction Thread
    Don't some guys run Grand Am brakes in the back to save some weight?
    04 Comp G.
  16. #16 Re: Official Weight Reduction Thread
    May 2013
    Dallas TX
    it really boils down to trying to reduce as much weight from the front since our cars are so nose heavy to get the car better balanced. Ive currently got the LeMons car down to 2880lbs. but still close to a 65% front 35% rear balance....trying to get it a bit better, but can only go so far with this platform. you can see some of the mods done in my official LeMons car question and answer thread
    Team JB-Weld
  17. #17 Re: Official Weight Reduction Thread
    Dec 2012
    Quote Originally Posted by Ginseng View Post
    You're right, I'll fix it.
    Sold.
  18. #18 Re: Official Weight Reduction Thread
    Bunnell, FL
    I dd'd a gtp with no carpet, headliner, rear seat or most trim
    Btw there is a thread on club gp with the weight of most nonessential pays off a gp down to the hardware
    I'm a Sex Offender
  1. Fullblown rice car 99 gtp. Might go bye bye
    By 87IROCZOWNER69 in forum Members Rides
    Last Post: 05-03-2015, 01:29 AM
  2. Weight Loss or Weight Gain Thread "2012"
    By benner in forum Off Topic Discussion
    Last Post: 08-24-2014, 12:27 AM
  3. Replies: 296
    Last Post: 08-02-2014, 09:56 PM
  4. Weight reduction
    By Clar2478 in forum General Tech Discussion
    Last Post: 01-11-2011, 06:01 PM
  5. Weight Reduction Tips
    By Quicklynx in forum General Tech Discussion
    Last Post: 02-07-2009, 11:11 AM
