Thread: Help with odd warning light combo
Results 1 to 3 of 3
  1. #1 Help with odd warning light combo
    Aug 2013
    NJ
    Hi everyone. I am new to the board and have a 95 GP SE.
    About a week ago, The ABS warning indicator and the TEMP warning indicator both came on (at the same time) and have not gone off since. The temperature is absolutely normal and the brakes appear to be fine as far as I can tell. Also, the LOW FUEL warning indicator light seems to be sporadically lighting up as well, although that one usually fades back out while driving....the fuel tank is full by the way. Any one experience this before, or have an idea what might be common to those three sensors or circuits that might cause this ? Thanks in advance for any help that is offered.
  2. #2 Re: Help with odd warning light combo
    SWPA
    Could be a voltage issue. Might want to have your alternator tested.
  3. #3 Re: Help with odd warning light combo
    id start with the main grounds (trans bell housing) and the ground to the body near the battery. as well as the battery terminals. make sure they are all tight, and clean.
  1. Brake Warning Light
    By tgarison in forum Brakes/Suspension/Chassis
    Last Post: 09-07-2011, 06:53 PM
  2. Low Coolant Warning Light
    By cutiger80 in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 07-26-2011, 11:19 PM
  3. Oil warning light
    By Skrappi69 in forum General Tech Discussion
    Last Post: 04-04-2011, 05:24 PM
  4. warning light
    By theextreem in forum Shops and Community Heroes
    Last Post: 03-06-2010, 02:01 PM
  5. ABS warning light
    By BankRupt in forum General Tech Discussion
    Last Post: 07-15-2008, 12:48 AM
