Thread: oxy sensor code
Results 1 to 6 of 6
  1. #1 oxy sensor code
    Aug 2013
    mpls, mn
    had code 0140 for awhile. changed rear sensor. code went away. for 1 yr. code is back. along with 0102, maf, low voltage. changed maf and than i got code 1404, egr pintle range. what the bleep? so, 0102 is gone which is good but i still have 0140. i think the egr code is gone since i have not seen it in 24hrs but the 0140 remains. so, low or no voltage. does that mean dead or dying rear sensor?
  2. #2 Re: oxy sensor code
    check the wires to the o2 for damage.
  3. #3 Re: oxy sensor code
    Aug 2013
    mpls, mn
    Well, I did replace my trans last week. But I had 0140 before I did any work. I was very careful doing work. Did not yank any wires or break any connectors. Quite a smooth job for once. Did a trans in 2nd car last fall. Getting good at this.
  4. #4 Re: oxy sensor code
    Dec 2012
    Where 4T65E's were born
    What brand sensor did you install? I have the same code, and another (P0140, P0141). I'd use oem sensors since most sensors provide critical data for the computer to run the engine properly. A slight bit difference in aftermarket sensors can sometimes cause issues, or they may not last.
    Sold.
  5. #5 Re: oxy sensor code
    Feb 2013
    Missouri
    Doesn't the secondary 02 sensor only verify if the cat is working or not? I was under the impression that the first 02 sensor is the important one.
  6. #6 Re: oxy sensor code
    Dec 2012
    That is right, I was talking about sensors in general. But I believe 01+ does a catalytic test or something that is needed.
    Sold.
  1. Car bogs at low rpm And still o2 Sensor code
    By DrSnazzy in forum General Tech Discussion
    Last Post: 02-22-2012, 10:48 PM
  2. Can a bad O2 sensor cause a misfire code?
    By Spartanzz in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 12-29-2010, 08:01 AM
  3. Help w/ O2 Sensor code
    By MooseGundr in forum General Tech Discussion
    Last Post: 12-03-2010, 12:18 AM
  4. p0420 code, which o2 sensor do i replace?
    By Golman76 in forum General Tech Discussion
    Last Post: 02-15-2010, 10:50 PM
  5. po341 cam sensor circuit code
    By TorqueAutoMotiv in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 12-19-2009, 12:07 AM
