Thread: Running Trans oil as engine oil
Results 1 to 20 of 23
04CompG Running Trans oil as engine... 11-19-2008, 04:24 PM
Zef_66 Re: Running Trans oil as... 11-19-2008, 04:44 PM
SyntheticShield Re: Running Trans oil as... 11-19-2008, 04:48 PM
Sabrewings Re: Running Trans oil as... 11-19-2008, 06:11 PM
SyntheticShield Re: Running Trans oil as... 11-19-2008, 06:16 PM
Street Wolf Re: Running Trans oil as... 11-19-2008, 06:32 PM
04CompG Re: Running Trans oil as... 11-19-2008, 10:03 PM
SyntheticShield Re: Running Trans oil as... 11-19-2008, 10:09 PM
Freebeer187 Re: Running Trans oil as... 11-21-2008, 01:31 AM
BackInBlack Re: Running Trans oil as... 11-19-2008, 10:52 PM
Sabrewings Re: Running Trans oil as... 11-19-2008, 10:57 PM
SyntheticShield Re: Running Trans oil as... 11-19-2008, 11:29 PM
Zef_66 Re: Running Trans oil as... 11-20-2008, 10:11 AM
JoshMcMadMac Re: Running Trans oil as... 11-20-2008, 11:22 AM
SyntheticShield Re: Running Trans oil as... 11-20-2008, 10:41 AM
Toofastgs Re: Running Trans oil as... 11-20-2008, 01:53 PM
SyntheticShield Re: Running Trans oil as... 11-20-2008, 02:08 PM
02BlueGT Re: Running Trans oil as... 11-21-2008, 02:36 AM
Sabrewings Re: Running Trans oil as... 11-20-2008, 06:35 PM
SyntheticShield Re: Running Trans oil as... 11-20-2008, 07:07 PM
chrisb Re: Running Trans oil as... 11-20-2008, 10:13 PM
SyntheticShield Re: Running Trans oil as... 11-21-2008, 06:59 AM
FuglyGTP Re: Running Trans oil as... 11-25-2008, 12:09 AM
  1. #1 Running Trans oil as engine oil
    GT Level Member 04CompG's Avatar
    Feb 2008
    South Bend, IN
    So one of my friends was telling me that one of his friends ran his engine completely with just trans fluid. meaning he would fill up his engine with trans fluid, not oil. He said that you can do this but you have to start doing it on a brand new engine that has never seen oil before.
    So whats up with this.
    2004 GTP CompG. SPO Package.
    3.6MPS, 3" DP, Powerlog, 180Tstat, Wizair, Autolite 104's, 20* timing, PRJ Wires. PRJ Tune.
  2. #2 Re: Running Trans oil as engine oil
    PA
    Quote Originally Posted by 04CompG View Post
    I wouldn't try it if I were you. Bad things would happen. Engine oil is for engines. Transmission fluid is for transmissions. They are made completely different for the different applications and different environments. Trans fluid will not hold up under the pressures of an engine.
    2001 GSE
  3. #3 Re: Running Trans oil as engine oil
    Oklahoma
    Agreed. Trans fluid is generally thinner than motor oil, does not have the extreme pressure additive motor oil has and nor does tranny fluid have the additive package to keep contamination in suspension or to combat combustion process by-products.
  4. #4 Re: Running Trans oil as engine oil
    Barksdale AFB, LA
    I've heard of it being done for 50 miles prior to an oil change under the assumption it will clean the engine out (an assumption I'm not sold on). Never heard of it being done all the time.
    2009 Subaru Impreza WRX STI
  5. #5 Re: Running Trans oil as engine oil
    Oklahoma
    I promise you transmission fluid has NO WHERE near the cleaning properties that motor oil does. I dont know how that ever got started but transmission fluid has virtually nothing in the way of cleaning abilities.
    Now what I could 'possibly' conceive it doing, since its a thin oil, on the thin side of a 20 weight motor oil, is maybe allowing the engine to run warmer and maybe burn some stuff out but thats a stretch at best.
    You want serious engine cleaning ability, pick up a bottle of Auto-RX. By far, bar none THE best engine cleaner man has ever known.
  6. #6 Re: Running Trans oil as engine oil
    Banned
    Wichita Falls, Texas
    Heard of it, seen it done, thought it was a stupid idea, researched it, found that it was indeed a dumb ass idea rather than just a stupid idea.
  7. #7 Re: Running Trans oil as engine oil
    Feb 2008
    South Bend, IN
    syntheticshield your telling me that Amsoil doesnt have the best engine cleaner???
  8. #8 Re: Running Trans oil as engine oil
    Oklahoma
    As much as I hate to say it, 'tis true. Now Amsoil's Engine Flush is a good product and one of only a handful of such products that doesnt contain Kerosene, but its not really targeted to do the work that Auto RX does. Look at it like this.
    You go to the bathroom and wash your hands (hopefully) after all is done. Thats Amsoils Engine Flush. A surgeon litterally scrubs his hands before surgery. Thats Auto RX.
  9. #9 Re: Running Trans oil as engine oil
    GTX Level Member Freebeer187's Avatar
    Bartlett, IL
    Quote Originally Posted by Street Wolf View Post
    lol hell yeah
    How To: E-Brake Pwn
    2001 GTP. D/S Rotors * Custom Intake * DHP PCM *
    Looking For - 3" in DP with Cat. PM me if selling
  10. #10 Re: Running Trans oil as engine oil
    GT Level Member BackInBlack's Avatar
    Vermont
    Isn't transmission fluid just modified hydraulic oil? I've heard of using 30w engine oil in a hydraulic pump, but never the other way 'round. Though you can run a little kerosene in your engine to clean it out some...
    The GPs are long gone...
  11. #11 Re: Running Trans oil as engine oil
    Barksdale AFB, LA
    Actually, automatic tranny fluid is a lubrication oil designed to be used as a hydraulic fluid. It lubricates, provides pressure, and cools the tranny.
  12. #12 Re: Running Trans oil as engine oil
    Oklahoma
    Correct, that is why you find some makers specify Automatic transmission fluid in their power steering systems.
  13. #13 Re: Running Trans oil as engine oil
    PA
    I have used tranny fluid as PS fluid before. No issues there.
    2001 GSE
  14. #14 Re: Running Trans oil as engine oil
    GTP Level Member JoshMcMadMac's Avatar
    Waynesboro, PA
    Quote Originally Posted by Zef_66 View Post
    Yea, it is an "old school" sort of "trick" that ATF has a lot more detergent to help clean out systems, like the power steering. I would not condone it, honestly, as you are better off just flushing the system and installing a filter if there is that big of a concern. How it turned into the oiling system as the OP suggests baffles me a bit, though.
    2000 NavyBlueMetallic GTP Coupe
    HPTuners / Intercooler / Devil's Own Meth / 1.8 SLP Rockers / 3.1-3.3" / 180° / TB Shield / FWI / PLOG / Jimmy-C Downpipe / U-Bend Delete / Mark VIII Fan / Alt. rewire / FP rewire / F-Body Brakes / Buick Strut Braces / SLP Tips / 20% Tint
  15. #15 Re: Running Trans oil as engine oil
    Oklahoma
    Yeah, there are some applications that call for it, GM unfortunately, specifically the GP isnt one of them, though Ive been tempted to try it out.
  16. #16 Re: Running Trans oil as engine oil
    GTX Level Member Toofastgs's Avatar
    Tulsa, Ok
    Tranny fluid is good for fuel injector cleaner if added to gas tank
    00' GTP 350/420 - Retired
    98' GS - Sold
    Current - Lexus ES300
  17. #17 Re: Running Trans oil as engine oil
    Oklahoma
    Sorry, it wont work as a fuel injector cleaner either. Its cleaning abilities are limited at best and used in fuel it would only become less so. It will, however, serve as a lubricant for the pump. In fact it is used frequently for that purpose in home made octane boosters.
  18. #18 Re: Running Trans oil as engine oil
    Hoffman/Schaumburg, IL
    doesn't ATF swell rubber as well? Our fuel system doesn't have much rubber from the factory, but a Fuel system with a rubber line may suffer if ATF is added........
  19. #19 Re: Running Trans oil as engine oil
    Barksdale AFB, LA
    Ford uses ATF as PS fluid a lot. Seen a lot of Cougars like that.
  20. #20 Re: Running Trans oil as engine oil
    Oklahoma
    Right, Ford is one of them that uses ATF in their PS systems. I sure wish others like GM would catch on.
  1. Autozone SOLID engine and trans mounts
    By Abrasive in forum Shops and Community Heroes
    Last Post: 08-17-2009, 08:19 PM
  2. engine or trans?
    By BankRupt in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 11-01-2008, 05:43 PM
  3. P1133 Engine not running smooth?????
    By Gearhed42 in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 05-21-2008, 12:23 PM
  4. Engine running too cold?
    By Deezul_AwT in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 03-02-2008, 07:41 PM
