Thread: Running Trans oil as engine oil
Results 1 to 20 of 23
  1. #1 Re: Running Trans oil as engine oil
    Oklahoma
    Correct, that is why you find some makers specify Automatic transmission fluid in their power steering systems.
  2. #2 Re: Running Trans oil as engine oil
    PA
    I have used tranny fluid as PS fluid before. No issues there.
    2001 GSE
  3. #3 Re: Running Trans oil as engine oil
    GTP Level Member JoshMcMadMac's Avatar
    Waynesboro, PA
    Quote Originally Posted by Zef_66 View Post
    Yea, it is an "old school" sort of "trick" that ATF has a lot more detergent to help clean out systems, like the power steering. I would not condone it, honestly, as you are better off just flushing the system and installing a filter if there is that big of a concern. How it turned into the oiling system as the OP suggests baffles me a bit, though.
    2000 NavyBlueMetallic GTP Coupe
    HPTuners / Intercooler / Devil's Own Meth / 1.8 SLP Rockers / 3.1-3.3" / 180° / TB Shield / FWI / PLOG / Jimmy-C Downpipe / U-Bend Delete / Mark VIII Fan / Alt. rewire / FP rewire / F-Body Brakes / Buick Strut Braces / SLP Tips / 20% Tint
  1. Autozone SOLID engine and trans mounts
    By Abrasive in forum Shops and Community Heroes
    Last Post: 08-17-2009, 08:19 PM
  2. engine or trans?
    By BankRupt in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 11-01-2008, 05:43 PM
  3. P1133 Engine not running smooth?????
    By Gearhed42 in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 05-21-2008, 12:23 PM
  4. Engine running too cold?
    By Deezul_AwT in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 03-02-2008, 07:41 PM
