Thread: Need better lighting in tinted tails!!!
Results 1 to 12 of 12
  1. #1 Need better lighting in tinted tails!!!
    Aug 2008
    as
    I've been trying to find a way to make my tinted tails brighter. Been searching day and night on this forum a lot of talk but no how-too guides. Is led the best way to go as far as brightness? Also, if i use leds wont that make them flash weird or through a code or light out or something like that? So what do i have to do? Do I have to install resistors? Will that be safe, wont they got too hot? Cant you modify your flasher module for cheaper and more safely? I want to do this as cheap as possible but have no idea how to do this so if you can help it be very appreciated!
  2. #2 Re: Need better lighting in tinted tails!!!
    Charles City, IA
    V-LEDS.COM High Power, SMT, Super Bright LEDs, HID Headlight Kits, Automotive Interior & Exterior LED Bulbs
    I believe you can just plug these in to the stock socket. Some one correct me if I am wrong. You just have to find the right bulb for the socket.
    SMGPFC Two Nipple General
  3. #3 Re: Need better lighting in tinted tails!!!
    Aug 2008
    as
    I'm really just trying to find out how to mod the stock tails to make leds work i already have them just wanted to know what i need to do i don't want to buy anything more if i don't have to i know you can mod them i just need to know how
  4. #4 Re: Need better lighting in tinted tails!!!
    for LEDs, unless it's prewired in for the car, you have to run a resistor in series with it since the resistance is much lower and youll get hyperflash (really fast blinkers).
  5. #5 Re: Need better lighting in tinted tails!!!
    GT Level Member Preotic's Avatar
    Missoula, MT
    I used a modified flasher i purchased from Back in Black. If your comfortable with soldering little itty bitty things, he explains how to modify your own flasher on his website.
    L26,Xp, zzp trans,3.29's,2700 conv, slp headers/catback, diy ported heads/LIM, 3 angle valve job,.052 MLS hg, outlet ported Gen V, 3.6, N*, LQ4, 4" FWI, agx's, ssc's, f-bodys, gmpp sway's +stb's
  6. #6 Re: Need better lighting in tinted tails!!!
    Aug 2008
    as
    yeah i think that's the best way to go as far as cheap and effective! So all i have to do is mod my flasher according to backinblacks mod and i can use any leds i want in the tails? correct? sorry just want to know that's right before i mess anything up.
  7. #7 Re: Need better lighting in tinted tails!!!
    Missoula, MT
    You can put led's in your tails no problem, if you don't mod your flasher the tails will blink really fast when you use the blinker. The Led's draw such a small amount of power that your flasher thinks a bulb is out and hyperflashes to let you know a bulb is out. Other than really fast blinkers the leds aren't going to harm anything if you don't mod your flasher.
  8. #8 Re: Need better lighting in tinted tails!!!
    Nov 2008
    Cedar Rapids, IA
    You can also just get a higher wattage stock bulb. Check out summit they usually have some. It may be a lot easier way to go for you.
  9. #9 Re: Need better lighting in tinted tails!!!
    I live here. UR LOSN's Avatar
    Rockford, IL
    there is a LOT of info in this thread...
  10. #10 Re: Need better lighting in tinted tails!!!
    Aug 2008
    as
    Thanks for all the quick replies! I think I'm going to mod my flasher BackinBlack seems to have the mod down, here is his link for it... Hyperflash Mod
    He has some cool mods on his site, also.
    He says to use a 260k OHM 1/4 Watt resistor or smaller, and solder that in replacement of the factory resistor, then solder in a Jumper wire. I think I can to this it looks easy enough, but has anyone done this before? How do I know if that 260k .25 watt will be okay for the leds I'm going to be using in the tail lights?
    I was thinking of just buying some leds bulbs that have 20 to 36 leds on it, think that mod will work or use a different resistor? Thanks for helping me I know I'm a pain.
  11. #11 Re: Need better lighting in tinted tails!!!
    Aug 2008
    as
    after i do this mod I'm going to post pics and show how i did it
  12. #12 Re: Need better lighting in tinted tails!!!
    Aug 2008
    as
    today i just put some 3457 bulbs in and that seemed to work great thanks everyone!
  1. Replies: 7
    Last Post: 02-20-2012, 09:35 AM
  2. Back up lights for tinted tails?
    By TheOtherNick in forum Visual/Body Modifications
    Last Post: 12-20-2008, 09:36 PM
  3. Spiderlites and tinted tails
    By Preotic in forum Visual/Body Modifications
    Last Post: 02-21-2008, 02:34 AM
