Thread: engine and trans motor mount
Results 1 to 10 of 10
  1. #1 engine and trans motor mount
    Jun 2013
    Hollywood ,FL
    just put in my poly urethane upper dogbone mounts from intense am wondering should I also replace my lower engine and trans mount if so which is the recommended brand ones to get also should I change just the engine or the tranny mount as well?
  2. #2 Re: engine and trans motor mount
    Kemmerer, Wyoming
    Unless they are broken I wouldn't worry about replacing them. If you put a solid/poly motor and transmission mount felt vibration to a more then noticeable amount
  3. #3 Re: engine and trans motor mount
    Jun 2013
    Hollywood ,FL
    Yea I know some ppl say replace them with factory autozone ones when u say broke do you mean torn or soft like the engine.can move
  4. #4 Re: engine and trans motor mount
    if it looks like this its shot lol
  5. #5 Re: engine and trans motor mount
    Jun 2013
    Hollywood ,FL
    lmao damnnnnnnn my tranny def doesn't look like that I pulled and pushed on the engine it didn't sway at all im guessing there fine?
  6. #6 Re: engine and trans motor mount
    Arizona
    Here's a general rule to go by, if youve owned the car and don't know if the motor mounts we're ever changed out, its safe to say you should replace them an be done with it.
    Motor mounts in general are a quick job unless you got lucky like I did with my GTP and the stud spins inside the motor mount. Then it turns fun..
  7. #7 Re: engine and trans motor mount
    thats a motor mount, oil leaks will will kill it, the oil makes the rubber soft, then it breaks down, and looks like that. i pulled 3 hand fulls of rubber out of the frame.
    my engine was moving 3 inches on the pass side when i shifted from drive to reverse.( both ways) dog bones were twisting as well. never had a vibration believe it or not lol
  8. #8 Re: engine and trans motor mount
    Jun 2013
    Hollywood ,FL
    Yea my cars used I'm just swapping out everything slowly I want to upgrade my brakes next but not sure which to buy and also my struts
  9. #9 Re: engine and trans motor mount
    Pennsylvania, USA
    It's worth to note that if you go solid (rubber that is, poly lower mounts only for racekar), you may want to drill into them to be sure they're really solid. I've yet to receive a "solid" mount without fluid in it, including ones that didn't make any noise when shaken.
  10. #10 Re: engine and trans motor mount
    gardner,mass
    Press in brake and put car in drive and revers and press throttle to feel the play in engine
    RPF1 17x9 255/45 Direzza Zll
    04 COMPG- Vs, getrag 284 RIP
  1. How to change lower motor mount and trans mount
    By AlanP in forum How To Write-Ups/Tech Tips
    Last Post: 01-10-2021, 12:39 AM
  2. solid motor and trans mount
    By 1996pontiac in forum Brakes/Suspension/Chassis
    Last Post: 08-08-2013, 01:54 PM
  3. Motor and trans mount swapping
    By BillBoost37 in forum General Tech Discussion
    Last Post: 04-18-2013, 12:00 PM
  4. Motor and Trans mount
    By Logan541 in forum General Tech Discussion
    Last Post: 06-25-2012, 08:19 PM
  5. Motor and Trans mount
    Last Post: 01-21-2012, 02:37 PM
