Thread: How to remove A/C high side service port?
Results 1 to 11 of 11
  1. #1 How to remove A/C high side service port?
    Friendswood, TX
    I've got a leak in the A/C high side service port and need to replace it. I had assumed that I just use two wrenches, one to hold the hex welded to the high pressure line and the other to loosen the valve. I feel like I'm going to twist and break something. Am I doing something wrong? Can anyone tell me how to correctly remove the service port?
  2. #2 Re: How to remove A/C high side service port?
    GT Level Member orange57's Avatar
    Aug 2012
    Chandler, AZ
    You may just need to replace the shcrader valve.
    matt
    2004 Grand Prix GTP - work in progress
  3. #3 Re: How to remove A/C high side service port?
    canal winchester, ohio
    Any tips on removing high side port?
  4. #4 Re: How to remove A/C high side service port?
    Aug 2016
    MN
    This post is super old, but I would second replacing the Schrader valve first. You do not want to twist the weld off or you'll be replacing the whole line assembly. Although that would fix your problem.
    1998 Grand Prix GTP aka The Family Sedan
    CAI, 1.8 rockers, U-bend delete, 3.4 pulley, tuned by me
    1999 Turbo Grand Prix
    L36 turbo build in progress
  5. #5 Re: How to remove A/C high side service port?
    Apr 2014
    CT
    I cant remember if I am confusing this with an intrigue. There may not be a traditional shraeder. Is there a black rubber looking material down the center? You may have to grab the bottom with vice grips and the upper portion has 2 flats on it that you get a wrench on.
  6. #6 Re: How to remove A/C high side service port?
    Apr 2014
    CT
  7. #7 Re: How to remove A/C high side service port?
    No Schrader valve. People say the cap is the primary seal but if I can get the port off without any troubles I would like to change it. I was running mine without a cap for years....no wonder I was losing freon. The port is leaking, slow, but definitely leaking freon.
  8. #8 Re: How to remove A/C high side service port?
    Apr 2014
    CT
  9. #9 Re: How to remove A/C high side service port?
    Ok so I ordered the socket and the new high port valve (no Schrader valve btw). I put a 5/8 wrench on the bottom and using the special socket I can't get the valve to loosen. I didn't put a lot of pressure because, like the original poster, I feel like the aluminum tube is going to bend.
    I sprayed with PB blaster and will try later. Any issue you guys can see if I use a torch to heat up the valve?
    Thanks
  10. #10 Re: How to remove A/C high side service port?
    Apr 2014
    CT
    Quote Originally Posted by michael redmon View Post
    Thanks
    When I did it, I had to put a lot of pressure on it. I thought for sure something was going to break but it didnt. Good luck, It was scary for me too. However Ive done it twice now, once on an intrigue and the Grand prix. Both were tough but the line ended up being fine.
  11. #11 Re: How to remove A/C high side service port?
    Got it off. Get the socket. Brace bottom with 5/8th wrench.
  1. low side service port
    By cooper25 in forum 5.3L V8 (LS4)
    Last Post: 06-22-2013, 11:40 PM
  2. Trans cooler, Is there a high side and low side of radiator ?
    By JT2002GTP in forum General Tech Discussion
    Last Post: 03-28-2013, 03:05 PM
  3. No pressure on low side AC service port
    By tprkevin in forum 3.1L V6 (LHO/LG8)
    Last Post: 05-22-2012, 04:40 PM
  4. should i service high milege transmission
    By djwright1980 in forum General Tech Discussion
    Last Post: 03-18-2011, 05:57 PM
  5. Low side service port
    By Skatched in forum 3.1L V6 (LHO/LG8)
    Last Post: 07-01-2009, 03:21 PM
