Thread: Trans cooler, Is there a high side and low side of radiator ?
Results 1 to 3 of 3
JT2002GTP Trans cooler, Is there a high... 03-27-2013, 04:44 PM
BillBoost37 Re: Trans cooler, Is there a... 03-28-2013, 01:51 PM
JT2002GTP Re: Trans cooler, Is there a... 03-28-2013, 03:05 PM
  1. #1 Trans cooler, Is there a high side and low side of radiator ?
    Feb 2013
    Ohio
    Just picked up a trans cooler at Summit.Never hooked one up before. Is it as simple as the upper radiator line going to upper inlet on cooler, and lower to lower ? Thanks.
  2. #2 Re: Trans cooler, Is there a high side and low side of radiator ?
    This depends on the cooler. Some coolers have pressure drops etc to allow fluid to bypass the cooler until it heats up and becomes thin enough to pass through portions of the cooler.
    Please post model and instructions that came with it.
  3. #3 Re: Trans cooler, Is there a high side and low side of radiator ?
    Feb 2013
    Ohio
    It's a cheap one, Flex-a lite. Part # FLX-3818. Page 198 Summit catalog.
  1. Cooler line pops out at radiator. Dealership says I need a new radiator?!?! Pic
    By nickbuol in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 02-27-2013, 08:27 PM
  2. AC high side low side pressure
    By aeidian in forum General Tech Discussion
    Last Post: 07-16-2012, 10:47 PM
  3. What to replace radiator trans cooler lines with barbed fittings. Which to buy?
    By buickman104 in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 12-17-2011, 11:10 AM
  4. drivers side high beam wont work?
    By shawn3091 in forum General Tech Discussion
    Last Post: 10-20-2009, 10:11 PM
  5. Replies: 0
    Last Post: 08-09-2009, 07:01 PM
