Thread: Car dies
Results 1 to 16 of 16
  1. #1 Car dies
    Feb 2010
    TN
    Cars been running fine 97 gt 323,000 today coming off a stop sign at normal speed no jack rabbit it just bogged then dies cranks but wont turn over, sounds strong but no start. Now the last few days I can hear the door relays going on and off when I am in park or idle not sure if there is a connection. oil, trans fluid fine everything else seems normal about a month ago the heater blower shorted out. Stuck 50 miles from home car towed to shop. any ideas ICM maybe?
    Thanks
  2. #2 Re: Car dies
    you need to check for spark and fuel. one or the other is failing for one reason or another.
  3. #3 Re: Car dies
    Door relays etc clicking.. leads me to think you should also check grounds.
  4. #4 Re: Car dies
    Feb 2010
    TN
    Ok shop has been checking the car all morning they are stumped they tried the things I suggested, and thier own ideas and nothin' they said it should start
  5. #5 Re: Car dies
    Feb 2010
    TN
    They found it crank position sensor $350, including $45 for the tow and $45 to find the problem what a rip
  6. #6 Re: Car dies
    Banned
    Jan 2013
    Colorado
    323000 miles!?
  7. #7 Re: Car dies
    Quote Originally Posted by Logan541 View Post
    If you've replaced one yourself, you'll understand why the book time makes the cost go up.
  8. #8 Re: Car dies
    Feb 2010
    TN
    Well that wasn't it drove 22miles and dropped dead waiting for tow truck middle lane of interstate 65 on a hill and people blowing horns and giving me the finger like I did this on purpose
  9. #9 Re: Car dies
    Feb 2010
    TN
    QUOTE=camopaint0707;1102070]323000 miles!?[/QUOTE]
    yep why?
  10. #10 Re: Car dies
    He's jealous
  11. #11 Re: Car dies
    Feb 2010
    TN
    He's jealous
    Original owner at 290,000 I changed struts tie rods and a arms. tune it every 100,000 change oil regular whenever that thing on the DIC says. Tranny fluid change every 60,0000. New CV shafts at 300,000. ICM at 250,000 and again at 300,000. 4 sets of tires so far 4 sets of brakes. power steering hose and pump, ac compressor , dryer, evaporter at 225,000. I say not to bad now if I can just figure this mess out
  12. #12 Re: Car dies
    Feb 2010
    TN
    Replaced ICM harness that goes with it checked Grounds same thing shuts off in a few miles somebody at work is saying gas filter that make any sense?
  13. #13 Re: Car dies
    it could be a bad fuel pump, id get a pressure gauge with a long fitting so you can see it while driving, if it drops pressure then stalls you found the problem.
    the pressure should not drop under 40 psi.
  14. #14 Re: Car dies
    Feb 2010
    TN
    Thanks will try
  15. #15 Re: Car dies
    Feb 2010
    TN
    Brought to a different shop they have been working on it since friday it has been running fine for them LOL gotta love it
  16. #16 Re: Car dies
    Feb 2010
    TN
    well other shop had it for two weeks can find no problem after two weeks they are returning it no charge said it is running fine but I am worried about taking it on a long trip
  1. My car dies out
    By metalexa1 in forum 3.1L V6 (LHO/LG8)
    Last Post: 03-22-2013, 04:54 PM
  2. Car Dies
    By montecarlo3800 in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 06-24-2011, 08:05 PM
  3. car dies if I take oil cap off
    By Corona99GT in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 04-14-2011, 11:25 AM
  4. Car dies out......HELP!!!
    By L KELLS in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 01-27-2011, 11:41 AM
  5. Car Dies
    By kfish in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 11-28-2009, 04:14 PM
