Thread: Supercharger Fill Plug
Results 1 to 20 of 27
  1. #1 Supercharger Fill Plug
    GT Level Member 2FASTGTP's Avatar
    Apr 2012
    Indiana
    On my 98 GTP, the SC had a black fill plug that required a torx to remove it. Well that stripped so I ordered a new one, the one they sent is gold with an Alan head wrench removal. Will it still fit?
  2. #2 Re: Supercharger Fill Plug
    It should. Only one way to find out...go out and take the 30 sec it takes to install it.
    It's quicker to go try it rather then waiting for a response on here.
    04 Comp G.
  3. #3 Re: Supercharger Fill Plug
    That is odd that it was a torques bit. All the ones I have seen were alen head.
  4. #4 Re: Supercharger Fill Plug
    Feb 2013
    37.295091, -121.930053
    ^^ yep asking a question on a forum when it takes a few seconds to find out is just silly. IF im stuck and cant figure out how to get the bolt out then i will ask but that dont happen very often.
    im a cookie again yay me
    please learn to forum better.
    ^^new favorite quote
  5. #5 Re: Supercharger Fill Plug
    Howell, NJ
    I stripped mine on my genv too. I used the correct bit and everything.
    Its in there so damn tight, I couldnt even drill it out.
    I just plugged it with a screw and rtv
  6. #6 Re: Supercharger Fill Plug
    Apr 2012
    Indiana
    The only reason I asked before trying is because I don't want to Dremel the other one out and find that the other one doesn't fit, then be stuck without a plug.
  7. #7 Re: Supercharger Fill Plug
    You should be able to just look at it and tell if its going to fit or not. Have at it.
    04 Comp G.
  8. #8 Re: Supercharger Fill Plug
    Feb 2013
    you do know they make a tool to remove stuck bolts like for the SC bolt?
  9. #9 Re: Supercharger Fill Plug
    Bolt extractor
    Or just cut a slit and use a flathead
    04 Comp G.
  10. #10 Re: Supercharger Fill Plug
    Apr 2012
    Indiana
    Dremel did nothing....I might run to auto zone and see if I can find an extractor
  11. #11 Re: Supercharger Fill Plug
    Arizona
    You should try again with sc being hot see if that let's it crack loose I had to jam a bigger Allen head in there to take mine out.
  12. #12 Re: Supercharger Fill Plug
    Apr 2012
    Indiana
    Car is gonna be junked cuz I can't get a damn plug out. Now metal shards will just be floating in my SC oil, just great
  13. #13 Re: Supercharger Fill Plug
    Calm down
    04 Comp G.
  14. #14 Re: Supercharger Fill Plug
    Apr 2012
    Indiana
    Calm down
    Well it can't be good to have metal in the SC!
  15. #15 Re: Supercharger Fill Plug
    why would you cut all the way through the plug?
    try some heat, a plumbers soldering torch works good to warm up the snout around the plug, not the plug so much, the idea is to heat the outs side of the threads so they expand and the threads break free.
  16. #16 Re: Supercharger Fill Plug
    You freaking out about junking the car isn't going to fix the problem.
    Stop driving it. Take the snout off and get the plug out. drain the sc oil first if possible. If you weren't prepared for something like this to potentially happen you shouldn't have attempt to get the screw out when it stripped.
    04 Comp G.
  17. #17 Re: Supercharger Fill Plug
    Take a picture to...I have a feeling your not explaining the problem correctly.
    04 Comp G.
  18. #18 Re: Supercharger Fill Plug
    Apr 2012
    Indiana
    We're all good! Dad saves the day by jamming a torx in with a hammer. Somehow. Haha I tried earlier but I guess he has a lucky touch! But the supercharger oil is surprisingly full. I am trying to take pics of something and put them on here. Is the best way to copy and paste a photobucket link?
  19. #19 Re: Supercharger Fill Plug
    Copy and paste the [IMG] code here.
    Go pops. You probably should of just jammed a bigger torx in there from the get go lol.
    04 Comp G.
  20. #20 Re: Supercharger Fill Plug
    Apr 2012
    Indiana
  1. GM part number for s/c oil fill plug
    By gpse2000 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 09-18-2012, 10:28 PM
  2. SC Fill Plug striped
    By jacobmh27 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 10-06-2011, 02:25 PM
  3. S/C Fill Plug Seal
    By VinceJE in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 07-23-2009, 09:17 PM
  4. Supercharger Fill Hole Bolt Stripped
    By SyntheticShield in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 01-18-2008, 06:20 AM
