Ok my son got this 1998 GP GTP . The guy he bought it off of said it needed a chip. The battery was dead and it also wouldn't start. After buying the car we looked into the chip and it seems that this GP is not chipped, passkey, or Vat's equip. I then charged the battery and attemped to start the car. The car will crank over but will not start. So now I'm into doing the diagnostics on it. I checked all the fuses and relays and all seem fine. I then found that someone make a bad attempt to repair wires at the computer. I though I was going to get lucky finding those wires hacked. It turn out to be for the high and low speed cooling fans. So I made the proper repairing using solder and shrink tubing, and reconnected the computer. Still no start. Then I checked to see if the fuel pump was getting 12 volts since it didn't run. It wasn't. I then put 12 volts to it and its runs. Wont start still but Im still checking into if there is fuel in the tank and if I can get pressure into the rails. That what takes me here. The strange thing that is going on with the car is when I go to start the car all the dash lights come on, the parking light, plus the headlights and the tail lights. Then the DIC blinks zero's. So just for fun I swapped out my sons other 98 GTP computer to see if it woud change. Still nothing. The 11 ignition main relay under the hood buzzes like crazy. If I remove the relay the cars electronics bug out. The fuel pump speed resistor wiring starts to flash when I check it with my power probe. The Abs turns on and off and maybe some other thing. Also when I hook up my scan tool it wont communicate with it. I have 12 volts at the data link but I cant seem to pull up a diagram of the pins. Im thinking that the Bcm is bad or shorted. Someone put in a after market radio,with a sub then pulled it all out. I'm also thinking maybe he had an alarm in it and ripped that out too. Its hard doing this without wiring diagrams that I pull off the net so I ordered some from EBay. Any help would be appreciated
