unless you weld, take it to a muffler shop, if you have a factory cat back on there still the mufflers are welded on and need to be welded to the new Y pipe. same for the down pipe, have them fix whats broken with it. they can cut off the old flange, re weld it to a new down pipe. replace the flex if need be. or even replace a section of pipe if thats the case.
