Thread: exhaust help
Results 1 to 8 of 8
  1. #1 exhaust help
    Jan 2012
    Abilene, KS
    The other day I was driving home from work and dozed off put my car in the ditch and hit and culvert and ripped off my exhaust. I just ordered a new y for the end but my mufflers are ok and the intermediate pipe is still ok. I ordered a catless downpipe from zzp but I have slp headers and now that I have had a chance to look closer I don't think it will work. I got a few pictures but can't get them on and any input would appreciated on how to make it work if its possible. the headers go into a y and they join right before the flex pipe and there isn't any flange. should I cut it off at the top of the flex and cut the zzp downpipe and just weld it? whats your opinions?
  2. #2 Re: exhaust help
    Yup unless you get custom and have a shop weld it...the downpipe won't fit with the slp headers. Better off selling the downpipe in the classifieds and get some of your money back.
    04 Comp G.
  3. #3 Re: exhaust help
    Jan 2012
    Abilene, KS
    I figured thanks
  4. #4 Re: exhaust help
    Upload pics with photobucket
  5. #5 Re: exhaust help
    Jan 2012
    Abilene, KS
    http://www.slponline.com/product/310...Dual-Tips.html the headers go to a piece like on top except instead of the flange its welded to the flex. its an aftermarket system. I would take it to a shop but they wont be able to get it in til aug 8th and its my only car
  6. #6 Re: exhaust help
    Jan 2012
    Abilene, KS
    I don't got that
  7. #7 Re: exhaust help
    unless you weld, take it to a muffler shop, if you have a factory cat back on there still the mufflers are welded on and need to be welded to the new Y pipe. same for the down pipe, have them fix whats broken with it. they can cut off the old flange, re weld it to a new down pipe. replace the flex if need be. or even replace a section of pipe if thats the case.
  8. #8 Re: exhaust help
    your mufflers are clamped on the pipes? then its all been replaced one time. should be easy to deal with.
    the DP, id take it to a shop let them make heads or tails of it.
  1. 3.1 water coming from exhaust leak on exhaust manifold
    By ibhuff in forum 3.1L V6 (LHO/LG8)
    Last Post: 10-21-2011, 01:54 PM
  2. Is it safe to drive with an Header exhaust leak or any exhaust leak??
    By GOTIT4CHEAP16 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 01-11-2011, 05:45 PM
  3. VRS EXHAUST- Mandrel Exhaust kit.
    By Lion29GTP in forum General Tech Discussion
    Last Post: 03-18-2009, 02:47 AM
