rperry435
Youll have that code in the pcm because it saw the loss of that fuel enable signal from the bcm. (one more indication) your pcm has nothing to do with your no starting issues.
My advice for you would be find the part number from the dealership. (call the parts department) give them your last 8 of the vin and let them give you the price, then ask what the part number is. Then google that part number find it cheapest you can new. Take it to a dealership (or shop with tech2) with your car and programming should be a typical hour charge. Youll walk out for less than $100 labor. Problem solved.
Sent from my SPH-L710 using Tapatalk 2
