Thread: 2004 GTP Won't Start
Results 1 to 20 of 33
  1. #1 2004 GTP Won't Start
    Dec 2012
    Raleigh, North Carolina
    Hey guys I have a 2004 Pontiac Grand Prix GTP with 75,000 miles. The other day when I tried to start the car I got no response, no engine turning over at all so I assumed the battery was dead. Also I noticed the wiper blades were pointing up which I found odd since I had not used them the night before. The first thing I tried was to jump the car which did not work. So I got the battery tested at Autozone and I was told it was dead. I replaced the battery with a brand new one and the car still will not start. When I turn the key you can hear the fuel pump engage but no engine turning over. The keyless entry will not work, the power windows and locks do not work, and none of the lights inside the car and the radio dosn't work either. But you can hear a faint static coming out of the speakers even when the key is not in the ignition. However the headlights do work. So the battery is working and was part of the problem.. But now I am unsure what the actual problem is.. Possibly an electrical problem or my ignition swictch? Has anyone else encountered a similar problem? I have disconnected the battery so it does not get drained while the car is sitting. Any help or advice would be greatly appreciated. Thanks!
  2. #2 Re: 2004 GTP Won't Start
    GTX Level Member Bills1997GTP's Avatar
    Oct 2012
    Philadelphia
    Sound like an ignition switch but I could be wrong
  3. #3 Re: 2004 GTP Won't Start
    GTX Level Member acidcrashdburnd's Avatar
    Apr 2012
    Middletown DE
    Time to start checking fuses. Look at the one related to IGN or PCM under the hood and pass side dash.
    2005 GPGT- Top Swapped Click me! 15.5 @109
    2002 GPGT- slow and stock
    1993 Oldmobile 88
    - exploded the diff @158k
    GPF Resident Flowmaster Troll
  4. #4 Re: 2004 GTP Won't Start
    Jul 2013
    Raleigh, NC
    Hey guys, my name is Dave and I am sjw515's brother. I have been trying to help him diagnose/fix the car. I checked all the fuses that I can test (where you can see if they are blown) but some of the larger ones that are square shaped you can't really tell if they are bad or not. Anyone know how to test those?
    It does seem like it is something fail-safe related that is not allowing the car to start like a fuse, switch, or something like that. When you turn the key on, you hear the fuel pump engage as he said. Then, when you try to start the car, nothing happens. The starter doesn't even click or anything.
  5. #5 Re: 2004 GTP Won't Start
    Apr 2012
    Middletown DE
    Quote Originally Posted by dmw319 View Post
    When I blew the PCM fuse it would still click. Nothing about security on the DIC? it might just be a switch they do go bad in these cars.have you tried to jump the started to check if will even crank?
    1993 Oldmobile 88
  6. #6 Re: 2004 GTP Won't Start
    Jul 2013
    Raleigh, NC
    Quote Originally Posted by acidcrashdburnd View Post
    what is the DIC?
    I have not tried to jump the starter
  7. #7 Re: 2004 GTP Won't Start
    Oct 2012
    Philadelphia
    It's a screen on the dash that tells you the miles on your car
  8. #8 Re: 2004 GTP Won't Start
    Jul 2013
    Raleigh, NC
    Quote Originally Posted by Bills1997GTP View Post
    If I am remembering correctly, it is not lighting up as well as all the interior lights. I think the only light I could see was the check engine light. nothing else was responsive ( power dowers and locks, etc). headlights did work though...
  9. #9 Re: 2004 GTP Won't Start
    Apr 2012
    Middletown DE
    I would check the wires on the starter, check the wire on the alternator, check the grounds, check the power cable going to the fuse box under the hood..
    1993 Oldmobile 88
  10. #10 Re: 2004 GTP Won't Start
    Jul 2013
    Raleigh, NC
    I wonder if you BCM (body control module) has died. That is located on the drives side of the dash behind that panel covered by the CLOSED door. Also check the grounds at the transmission bell housing almost all of them are there.
    it controls almost everything in the cabin.
    is there a way to test it or narrow it down to that? otherwise we are just pulling it out and buying a new one? sounds expensive if its not the culprit.
    power cable to fusebox is good. can check the other wires/grounds also but it just feels like we would be taking a stab in the dark. the car is parked in an apartment complex and there aren't a lot of options for tools, etc. I was hoping to narrow down the issue to something given the issues we are having but i guess its never that easy
  11. #11 Re: 2004 GTP Won't Start
    Apr 2012
    Middletown DE
    1993 Oldmobile 88
  12. #12 Re: 2004 GTP Won't Start
    GTP Level Member rperry435's Avatar
    Oct 2011
    MI
    Ouch. Bad BCM.
    Sent from my SPH-L710 using Tapatalk 2
    '04 CompG - 3.6MPS - 104s - FWI - TOGS - w/14"SlimFans - SLP RR' s - 180HF Stat - TEP SK - Aluminum Oil Pan - 4thGen ZZP Wires - LS7 Lifters - AeroForce - AEM WB - HPTuners - FBSS Air Ride
    ASE & State Certified Auto Electrical Tech
  13. #13 Re: 2004 GTP Won't Start
    Jul 2013
    Raleigh, NC
    So there is no way to test to verify that it is actually the BCM is there? Also, where do you purchase one if we were to replace it?
    Also, jumping the starter would only verify that the ignition switch is bad, correct?
  14. #14 Re: 2004 GTP Won't Start
    Apr 2012
    Middletown DE
    Morad Parts Company - 3800 Motors, Transaxles, & Stock Parts
    You will probably need a tow to a stealership to reprogram it, unless you know someone with a GM Tech2 scanner. Give ed a call he will set you up.
    And it would give you an idea if the switch was bad, I don't actually think the car would start but it should at least crank.
    1993 Oldmobile 88
  15. #15 Re: 2004 GTP Won't Start
    Oct 2011
    MI
    Highly doubt the switch is bad. It's not like a switch from a 97-03. 04+ use a low amperage style switch. BCM must be programmed with a tech2. They CANNOT be used as they are locked after a few ignition cycles. Symptoms of a bad bcm are no Interior lights,security not enabling starter, locking issues, radio not powering on or locked, no communication with the bcm. Check your power and grounds at the unit other than that sounds text book bad bcm
    Jumping your starter will prove nothing other than the starter motor itself is fine. The car will still not run
  16. #16 Re: 2004 GTP Won't Start
    Jul 2013
    Raleigh, NC
    Thanks yall. It looks like the BCM is the most likely culprit at this time. (50-65 dollars aint bad!) We just need to find out how much a reprogramming costs at the dealership.
  17. #17 Re: 2004 GTP Won't Start
    Oct 2011
    MI
    There's no way in hell that a new bcm (body control module) is $60. You cannot put a used one in. PCM (powertrain) yes but not a BCM.
  18. #18 Re: 2004 GTP Won't Start
    Dec 2012
    Quote Originally Posted by rperry435 View Post
    He was looking at ones from ebay.. So they quite possible would be used ones. But I work for Carquest and can get a new BCM for $110. Thanks for all the help and ill keep you updated.
  19. #19 Re: 2004 GTP Won't Start
    Oct 2011
    MI
    No problem just trying to make sure no extra money is spent that's not nessesary
  20. #20 Re: 2004 GTP Won't Start
    Jul 2013
    Raleigh, NC
    can the used ones not be reprogrammed?
  1. 2004 no start
    By Dadillac in forum General Tech Discussion
    Last Post: 07-02-2013, 07:39 PM
  2. When did the 2004 GP actually start production?
    By Iceman83 in forum General Grand Prix Discussion
    Last Post: 02-16-2013, 11:02 PM
  3. 2004 Grand Prix reving on start up
    By Maxie in forum Engine
    Last Post: 11-11-2012, 10:44 AM
  4. hard to start 2004
    By twisted67 in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 09-13-2012, 09:37 PM
  5. 2004+ Remote start key fob - what are you guys getting for range? How to improve?
    By acammer in forum Audio, Security & Visual Electronics
    Last Post: 03-13-2011, 03:38 PM
