Thread: Need Help with Keys!
Results 1 to 12 of 12
transam24 Need Help with Keys! 07-20-2013, 03:49 PM
Speedy1973 Re: Need Help with Keys! 07-20-2013, 04:41 PM
FordMan77 Re: Need Help with Keys! 07-20-2013, 05:34 PM
BlackGT97 Re: Need Help with Keys! 07-20-2013, 05:56 PM
BlackGT97 Re: Need Help with Keys! 07-20-2013, 05:55 PM
Fivefingerdeathpunch Re: Need Help with Keys! 07-20-2013, 09:01 PM
transam24 Re: Need Help with Keys! 07-20-2013, 09:37 PM
Jomamma Re: Need Help with Keys! 07-20-2013, 09:41 PM
Fivefingerdeathpunch Re: Need Help with Keys! 07-20-2013, 09:51 PM
gtpeddie Re: Need Help with Keys! 07-20-2013, 09:58 PM
transam24 Re: Need Help with Keys! 07-22-2013, 06:38 PM
FordMan77 Re: Need Help with Keys! 07-22-2013, 09:05 PM
  1. #1 Need Help with Keys!
    SE Level Member transam24's Avatar
    Dec 2011
    NY
    Just picked up a 98 daytona pace car and it needs a new set of keys. Are the keys in the 98's chipped with passkey 1 or 2 and or VATS? Is there a way to just bypass the security system?
  2. #2 Re: Need Help with Keys!
    Apr 2012
    Bancroft. Ontario, Canada
    When you find a way to bypass the vats system, lmk...
    usually if their chipped, they'll say PK3 or something on the key, or just take it to wherever you get key's cut, and they can tell you
  3. #3 Re: Need Help with Keys!
    GrandPrix Junkie
    St. Louis
  4. #4 Re: Need Help with Keys!
    GTP Level Member BlackGT97's Avatar
    Jul 2011
    Michigan
    oh and the "chip" on the keys is just a resistor anyway lol
    1997 Grand prix GT Black Coupe- The beater
    1998 Grand prix GT Black coupe- Top swapped, XP cam
    2008 Grand prix Midnight blue- The slow but nice car
    1999 Chevrolet Silverado red ext. Cab
  5. #5 Re: Need Help with Keys!
    Jul 2011
    Michigan
    the 98s should not be chipped, all the VAT needs is a resistor to bypass it. Not hard to do at all really
  6. #6 Re: Need Help with Keys!
    I am pretty sure all 97-03 cars have PK3 keys.
  7. #7 Re: Need Help with Keys!
    Dec 2011
    NY
    How do I figure out if its pk2 or pk3 without the original keys? I would get the resistor value off the key if the keys i had were not just mechanical keys... Am I just going to have to go back to the dealer with my vin and proof of ownership?
  8. #8 Re: Need Help with Keys!
    Howell, NJ
    I'm pretty sure 97 and 98 did not have vats
    I know my 97 GTP does not.
  9. #9 Re: Need Help with Keys!
    I wonder if the sticker on the inside of the trunk with the RPO codes will have anything.
  10. #10 Re: Need Help with Keys!
    Jan 2012
    Philadelphia
    I know for 100% my 97 GTP does not have a chipped key, and Im pretty sure my 02 GT doesn't have a chip either
  11. #11 Re: Need Help with Keys!
    Dec 2011
    NY
    Got unchipped keys from the seller, charged up the battery, and the car turns over but doesn't start. Checked for spark but there isnt any. The fuel pump relay clicks but the pump does not come on. Also the DIC just flashes zero as a possibly related problem. Does this sound like a security issue or bad pcm? Where should i go from here?
    Edit. Also there is no scan tool communication
  12. #12 Re: Need Help with Keys!
    GrandPrix Junkie
    St. Louis
    Sounds like you need to check fuses. The cigarette lighter fuse also runs the OBD port IIRC.
    Check the fuses under the hood and inside. Also clean and tighten the battery cables as the DIC flashing zero sounds like a ground issue.
  1. keys...
    By ryanhancock in forum Introductions/Noob Questions
    Last Post: 12-07-2012, 06:38 PM
  2. no keys
    By 94grandprix in forum General Tech Discussion
    Last Post: 07-29-2012, 01:27 PM
  3. PK3 keys?
    By bat119 in forum General Tech Discussion
    Last Post: 07-13-2012, 07:30 PM
  4. Lost keys, what to do?
    By azmattaz06 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 09-17-2010, 11:35 PM
  5. Sometimes Can't Get Keys Out
    By ActionJackson1985 in forum General Tech Discussion
    Last Post: 11-12-2009, 03:02 PM
