Thread: Gas Gauge not working, I've tried everything!!!
Results 1 to 3 of 3
  1. #1 Gas Gauge not working, I've tried everything!!!
    Mar 2013
    United States
    Hi again guys! I've had this issue with my car since I got it. Gas gauge won't work. It's stuck at a hair over half way.
    Things we've already tried:
    • replaced entire fuel pump assembly - nothing
    • checked for bad wires - nothing
    • connected purple fuel sensor wire directly to sending unit - when disconnected it goes to empty, when again connected goes back to the hair over half a tank.
    Now the oddest thing. The cluster says it was a 1998 manufacture, and the car was manufactured in Sept. of 1996.
    Car is a 1997 Grand Prix SE 3.8L non-supercharged.
    Please help I'm at wits end! THANKS IN ADVANCE
    ALSO! If cluster is swapped out, do you thing it'll work or not? I read something about the 1997 gas gauge working differently ...and I'm pretty sure that the cluster was swapped without telling me before I bought it. Otherwise, it would be the same manufacture year right?
  2. #2 Re: Gas Gauge not working, I've tried everything!!!
    Mar 2013
    United States
    I made another post earlier in the wrong category, and I don't know how to change/remove it
  3. #3 Re: Gas Gauge not working, I've tried everything!!!
    Oh Great..you did it now.. another post means we can't answer your questions!
    I kid..
    Search for any technical bulletins for your year. The cluster seems like it's been replaced and IIRC there was a known issue with 97's and maybe adding a resistor.
  1. 01 GTP gas gauge not working
    By sheltonb13 in forum General Tech Discussion
    Last Post: 02-16-2013, 11:15 AM
  2. Gas Gauge not working!
    By gtpeddie in forum General Tech Discussion
    Last Post: 03-04-2012, 07:08 PM
  3. Gas Gauge not working
    By tooslow in forum General Tech Discussion
    Last Post: 08-07-2011, 02:37 PM
  4. gas gauge not working!!!!!!!
    By chancinit666 in forum General Tech Discussion
    Last Post: 06-04-2010, 03:54 PM
  5. Help!!! Gas Gas gauge not working
    By PontiacGTPSE in forum General Tech Discussion
    Last Post: 07-09-2009, 12:30 PM
