Thread: Code 1133
Results 1 to 16 of 16
  1. #1 Code 1133
    Feb 2013
    Ohio
    Ok, got about 50 miles on light mods including re flashed PCM from w body and catless down pipe. Got on it a couple times,nothing crazy. Got code 1133. Any suggestions ? Sounds like the PCM, or its just coincidence that sensor went bad after mods. Thanks.
  2. #2 Re: Code 1133
    It would be great if you could tell us what you drive, mods, changes that have been made to the pcm and what code 1133 stands for.
    Thanks
  3. #3 Re: Code 1133
    I used to get P1133 all the time when I installed my headers, the code stopped coming up about a month or 2 after install.
    Just clear it and be on your way and see if it comes back.
    Buying a new sensor wouldnt hurt either.
  4. #4 Re: Code 1133
    Feb 2013
    Ohio
    Thanks
    It's an 02 GTP 40 Anniversary. 85,000 miles. Wbody fender intake,3.5 pulley, 160 Stat, Autolite copper plugs, Catless down pipe, PCM with sensor after cat delete, wbody standard flash.trans cooler, Polly upper mounts. Larger SC tensioner. Code 1133 is HO2S Bank 1 sensor 1,It determines that front 02 did not switch enough times. It monitors heated oxygen, PCM determines if front sensor is functioning properly by counting the number of ho2s lean/ rich rich/lean
  5. #5 Re: Code 1133
    Typically this an O2 or O2 extension issue. If clearing it doesn't help, I'd give a new sensor a try. One thing to keep in mind is our cars somehow beat up on Bosch O2 sensors, so a Denso is probably the best priced option.
  6. #6 Re: Code 1133
    Feb 2013
    Ohio
    Ok, Thanks. What do you mean by extension issue ?
  7. #7 Re: Code 1133
    If someone has headers, often an extension is needed. Often routing isn't high on the list when excitement of headers and the first start up. Next thing you know something is burning...it's the O2 extension wiring...
  8. #8 Re: Code 1133
    Switch to a 180 thermo aswell, 160 is far too cold.
  9. #9 Re: Code 1133
    Feb 2013
    Ohio
    Really ? I didn't know that, I went by Wbody recomendation of 160. Is your 180 idea for a higher engine temp or will my 160 cause any malfunctions ?
  10. #10 Re: Code 1133
    Following what vendor website says is usually not the best idea.
    I don't recall any site saying a 160 thermostat is needed for mild mods or no mods.
    Only if you are hot lapping the car at a track is a 160 perhaps needed. The stock knock sensor settings dont turn them on till 160º, though you have a tuned PCM, they may still be the same.
    A 180 is what you swap in as the car would prefer those temps better.
  11. #11 Re: Code 1133
    Nov 2011
    NY
    If you don't tune in the lower temp t-stat then it's useless... 180 is low enough, 160 provides no benefit over the 180.
  12. #12 Re: Code 1133
    Feb 2013
    Ohio
    Im assuming since wbody flashed my PCM and recomended The 160 I should be good.
  13. #13 Re: Code 1133
    For cereal man, you dont want a 160 in there.
    We know what we are saying here.
  14. #14 Re: Code 1133
    Straight from Wbodystore's website.
    Which temperature thermostat should I choose? - We recommend the 180 degree thermostat for lightly modified supercharged vehicles and all naturally aspirated 3800s. We recommend the 160 degree thermostat for heavier modified supercharged vehicles in hotter climates. Most vehicles are very well suited with the 180 degree thermostat.
    2004+ Vehicles should only run the 180 degree thermostat
  15. #15 Re: Code 1133
    Feb 2013
    37.295091, -121.930053
    FFDP know what he is talking about. Do you? lol
    im a cookie again yay me
    please learn to forum better.
    ^^new favorite quote
  16. #16 Re: Code 1133
    Nov 2011
    NY
    Quote Originally Posted by JT2002GTP View Post
    the only way to now for sure is by reading the PCM and knowing what's programmed in there (160 fan settings).
    But like said already, the 160* will do NOTHING as far as benefit goes! It's not like it will cool the engine to any significant degree... Will only open sooner allowing coolant to flow, but the engine is still going to heat up way beyond the stat settings.
    Also the knock sensors are set to activate at the same temp (160*) and if/when in colder environment as I'm sure you get in OHIO, you run the risk of having the engine run at that temp without the knock sensors activated. Overall, people have done it, sure go ahead if that's what you want. But many will tell you it's to no benefit.
    As for the p1133, I got it too after my header install. I believe it has to do with the location of the front O2 sensor bung in the headers. I have a high flow cat as well which i think doesn't help. Some have moved the sensor into the crossover, I have yet to try the non fouler trick, but have ability to tune it (code) out which is what I did, sorry.
    Replace the O2 sensor, rockauto is your friend here, $30.
    And go from there...
    Good Luck!
  1. Code P1629 and Code P1573
    By gmsprincess in forum General Tech Discussion
    Last Post: 03-16-2013, 03:39 PM
  2. Code help
    By GTPRIX99 in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 10-25-2012, 06:16 AM
  3. bad idle maf code driver 6 line 4 code
    By GTPSHAWTY in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 07-04-2012, 05:56 PM
  4. '99 Grand Prix GT has code 1810, yet runs great as always, so why the code?
    By McFly1999 in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 03-03-2012, 07:52 AM
  5. help! code po 716
    By SteveCZ28 in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 02-11-2011, 07:38 AM
