Thread: 3.4 pulley drop
Results 1 to 13 of 13
  1. #1 3.4 pulley drop
    Jul 2013
    adrian, mi
    i just got everything but the pulley done. open cone filter, 104's, 3" dp, ported front manifold and 180* tstat. i scanned to check for kr and found none so i was wondering if i could drop to that 3.4 now.
  2. #2 Re: 3.4 pulley drop
    Go for it. Just make sure you scan when you are done.
  3. #3 Re: 3.4 pulley drop
    Max Cook
    Guest
    97-03 or 04+? 04+ you probably wont be able to get away with it. 97-03 you might be okay if you've got a pretty well maintained engine. As slick said just make sure you scan for KR after dropping and be careful.
  4. #4 Re: 3.4 pulley drop
    IIrc he has a 97-03.
  5. #5 Re: 3.4 pulley drop
    GTP Level Member Austins01GP's Avatar
    Nov 2010
    Maryville, MO
    just scan, if you get some kr, its just time for some headers
    // 1992 Nissan 300zx Twin Turbo (More RWHP than the Comp G)
    // 2005 Comp G
    CLICK ME!! for my Z Build and Comp G
  6. #6 Re: 3.4 pulley drop
    Jul 2013
    adrian, mi
    oh for sure scan after just wanted some opinions on doing it now. and its a gtp 98' sorry bout that
  7. #7 Re: 3.4 pulley drop
    Jul 2013
    adrian, mi
    so i put on the 3.4 last night im still not showing any kr. how often do knock sensors go bad? it ran realy well with it pulled hard and smooth. i was just expecting to see some here and there at shift points. but i ran it wot through 3rd gear and didnt see any. timing advance was 16* at wot and 27*-30* cruising
  8. #8 Re: 3.4 pulley drop
    Nov 2010
    Maryville, MO
    was the car at operating temperature during this?
    // 2005 Comp G
  9. #9 Re: 3.4 pulley drop
    Jul 2013
    adrian, mi
    yes it was. right about 180* 185*. i had been driving through town before i got on the highway
  10. #10 Re: 3.4 pulley drop
    Nov 2010
    Maryville, MO
    I think you'll be fine, i actually had the same thing happen to me after i put on my headers, but it started showing some knock at certain points
    Im not sure exactly how our knock sensors work, maybe someone else could shine some light on this, but in my z, the knock sensor is either working or broken. and you would get a check engine light when its broken.
    // 2005 Comp G
  11. #11 Re: 3.4 pulley drop
    Jul 2013
    adrian, mi
    yeah i just read it will throw a code if one is bad. so there good. thanks for the info
  12. #12 Re: 3.4 pulley drop
    Nov 2010
    Maryville, MO
    Np. enjoy that new found powaa
    // 2005 Comp G
  13. #13 Re: 3.4 pulley drop
    Jul 2013
    adrian, mi
    already did this morning . cant wait to get it to the track
  1. Should i drop to a 2.8 pulley?
    By GOTIT4CHEAP16 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 04-03-2013, 12:43 PM
  2. pulley drop help!
    By hockeybawler in forum General Grand Prix Discussion
    Last Post: 09-12-2012, 11:32 PM
  3. Pulley drop
    By deejayfb in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 11-18-2011, 10:52 PM
  4. Should i get a pcm tune for a 3.5 pulley drop?
    By okesongtp in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 08-28-2010, 02:03 PM
  5. pulley drop 05
    By wlmrt6 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 04-27-2010, 07:51 AM
